Side Trim Falling Off
6 replies to this topic
#1 charliedurrant
charliedurrant
  • 519 posts
  • Local Club: There isn't one down my way
Posted 13 September 2011 - 07:00 AM
Hi,
I have some plastic Crome effect side trim that goes the length of the car along the arches and under the doors etc.
Well its not really attached very well and I just wanted to know what glue anyone would suggest to use? I always thought super glue was no good with water?
Thanks in advance
Charlie
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 13 September 2011 - 08:03 AM
They should self grip, but as an extra precaution I run a bead of clear silicon down the inside of the strip before fitting permanently.
#3 charliedurrant
charliedurrant
  • 519 posts
Posted 13 September 2011 - 03:59 PM
I'll use some silicon! Good idea
#4 jakejakejake1
jakejakejake1
  • 644 posts
Posted 14 September 2011 - 12:28 AM
Mine are held on with duct tape, rolled into a cylinder (Sticky side out), then pushed inside the trim, which is then pushed on the car :)
#5 SolarB
SolarB
  • 1,387 posts
Posted 14 September 2011 - 09:42 AM
Mine are held on with underseal.
#6 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 15 September 2011 - 04:05 PM
If it's plastic trim then try heating small sections of it with a hairdryer until it goes soft and pliable, then carefully pinch each section of the trim with pliers or molegrips and hold until it goes cold again. This should close up the gap in the trim a little and make it grip better at those points. :thumbsup: (Use a piece of rag between the pliers/molegrips and the trim though, to avoid making unsightly indents/plier marks in the trim)
Edited by AVV IT, 15 September 2011 - 04:06 PM.
#7 charliedurrant
charliedurrant
  • 519 posts
Posted 16 September 2011 - 06:32 PM
Thanks - I haven't yet approached fixing it but I wil try the heat method first.
Charlie
