Md 266 Cam 1098 - Timing?
Posted 13 September 2011 - 07:22 AM
Posted 13 September 2011 - 09:54 AM
Posted 13 September 2011 - 10:32 AM
Posted 13 September 2011 - 10:37 AM
Posted 13 September 2011 - 11:58 AM
with a dizzy it will always be a case of 'the lease worst position' i.e. where it is about right for as much of the rev range as possible.
Posted 13 September 2011 - 12:25 PM
Incidentally, I am at the beginning of setting this up and assume that I should set ignition timing before going on to adjust the carbs which are twin 1.25" HS2. I also have a 295 head and LCB manifold if this has any implication - which I wouldn't have thought would for ignition timing.
Posted 13 September 2011 - 12:59 PM
The only way to adjust it to perfection is to have it setup on a rolling road and the dizzy recurved, or do the DIY equivalent which is mappable ignition and a wideband lambda sensor.
Posted 13 September 2011 - 01:39 PM
I'm using my old 850 45D4, which I know is going to be out on the advance curve, but have been told that it shouldn't make that much difference(?) The Haynes manual for a 1100 said about 16 degrees stroboscopic, but this had the engine running very lumpy. When I adjusted it so it ran OK and then checked with the light, it was off the timing marks completely. At this stage vacuum advance is not attached anyway. I was considering getting a non vacuum dizzy, but not sure how that affects driveability on a mild road car.
You should keep the vac advance, it's the only way the car can adjust the timing againat load. Dizzys are cr@p in all cases, but whover told you it wouldn't make any differance were either saying:
1) That all dizzys are rubbish and whatever one you fit it'll never be right, or
2) They had no real understanding of how the correct advance curve transform the performance of a car.
As above, forget the tickover, concentrate on whct it;s doing when it matters. Set to 30 deg at 4k (with vac disconnected) re-connect vac advance and try it.
As for what to do first, it's all a bit of one, then a bit of the other, but getting the basic timing somewhere close will make sorting the fuelling easier.
As has been said above try 30 deg at
