Any Tutorials On Engine Compression Testing?
16 replies to this topic
#1 stubbsy
stubbsy
  • 60 posts
Posted 13 September 2011 - 02:33 PM
Hi guys and gals
Got a suspicion that head gasket has gone so think i need to do a compression test??? are there any tutorials on how to do it or is it generally cheap enough to get a garage to do it??
Thanks in advance
Duncan
#2 Cooperman
  • 23,513 posts
Posted 13 September 2011 - 02:44 PM
It's a 10 minute job if you have a Gunson (or other suitable) compression tester.
Get the engine warm, take out all the plugs, undo the coil to distributor lead and fit the comp. tester to cylinder no. 1. Push the throttle to the floor and crank the engine for about 5 seconds. Record the reading. Repeat for cylinders 2, 3 & 4, recording each one. If you then need another opinion, post the figures on here.
Re-fit plugs and coil connection and it's all done.
#3 stubbsy
stubbsy
  • 60 posts
Posted 13 September 2011 - 02:50 PM
Thats great thanks, sounds straight forward. what kind of numbers am i looking for on a 998 ? does Stage one kit affect numbers???
Sorry i really am a novice
#4 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 13 September 2011 - 03:02 PM
Anything above 140-150 will be fine...So long as there is no more than a 5-10 per cent difference between bores.
#5 bcjames
bcjames
  • 2,741 posts
Posted 13 September 2011 - 03:06 PM
To add to the above, label your HT leads 1 to 4 as you disconnect them so you don't get stuck putting it back together. Apologies if that is pointing out the obvious!
#6 Cooperman
  • 23,513 posts
Posted 13 September 2011 - 04:27 PM
That's a good point. I usually put some dots of yellow paint on the plug caps to identify which is which.
A 'Stage 1' kit will only affect the figures if it includes a modified head with a raised compression ratio. The expression 'Stage 1' really has no meaning in engineering terms, as it's a sales expression, so it's impossible to say. However, if you get anything over about 145 psi it'll be fine. Just make sure the throttle is fully open when doing the test and that the engine has just been run so it's at operating temp.
#7 ZKruly87
ZKruly87
  • 114 posts
  • Local Club: Mini Wips
Posted 13 September 2011 - 04:33 PM
good advice. many a time i have full rebuilt an engine to put the plugs back on wrong.
#8 bushy46468
bushy46468
  • 56 posts
Posted 13 September 2011 - 04:45 PM
just out of interest how much is it for a garage to do / how much in the compression kit to D.I.Y.
#9 Cooperman
  • 23,513 posts
Posted 13 September 2011 - 04:54 PM
A Gunson Compression Tester should cost about £25 from Halfords or any good motor factors.
All you need as well is a plug spanner.
A garage would probably charge around £30.
#10 leroy26
leroy26
  • 2,239 posts
  • Local Club: minisunleashed.com
Posted 13 September 2011 - 04:59 PM
screwfix do them for seventeen!
#11 minidazza
minidazza
  • 27 posts
  • Local Club: Thames Valley Mini Club.
Posted 02 October 2013 - 01:04 PM
Great thead guys. I want to do a test on my 998 engine. Its nice that we can do jobs like this ourselves, than pay some cowboy to tell it is a gaskit, when it is just a spark plug. I will refer to this thread when I have bought a tester.
#12 daenesh
daenesh
  • 423 posts
  • Local Club: Classic Car Owners Group
Posted 30 December 2013 - 09:01 AM
sorry to butt in but what happens if you do a compression test but don't open the throttle fully? i think i might have made that mistake.. as in i forgot to open the throttle fully..
#13 minimadles
minimadles
  • 136 posts
  • Local Club: not as yet
Posted 30 December 2013 - 09:05 AM
You get an inaccurate result as the throttle butterfly causes a restriction to the incoming air that is subsequently compressed
#14 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 30 December 2013 - 09:08 AM
Did that on my first clubman when I serviced it for the first time. I think it was 2 and 3 I mixed up. It still ran (I got about half a mile) but rough as anything.
#15 daenesh
daenesh
  • 423 posts
Posted 30 December 2013 - 10:13 AM
I think i definitely made a mistake there.. haha didnt even warm up the engine as well.. too many rookie mistakes
