Full Head Freddy Mask Latex How To?
Posted 14 September 2011 - 03:15 AM
Basically i was wondering if anyone out there knows the process and products involved?
Posted 14 September 2011 - 12:45 PM
Posted 14 September 2011 - 01:03 PM
Freddy Mercury?
It's spelt Freddie, darling
Posted 14 September 2011 - 01:31 PM
Posted 14 September 2011 - 01:58 PM
Looky here http://www.maragon.c.../life-cast.html.
Personally, I'd use silicone or alginate.
Posted 14 September 2011 - 04:14 PM
Posted 14 September 2011 - 08:09 PM
DO NOT try to do this by yourself, you may very well die. You need to have someone there monitoring you to make sure you are still breathing and who is prepared to rip it all off and possibly resuscitate you if it all goes wrong. They should know how to do this.
You need to apply all the alginate in a very short time, but work around so the nose is closed over last and REMEMBER THE BREATHING STRAWS. Two of them, in your nose. One or both may block, if both do you should stop immediately obviously and accept you have to start again. Also grease your eyebrows heavily with vaseline if you want to keep them. It is scary in there for the few minutes it's going off. You will need to decide where the seam is going, I think there tends to be just one seam from the crown down the back of your head to your neck. Athough if you are using alginate it may not be strong enough to fold and peel off around your whole head like that, you may need to make a front and back. You would have to experiment. You will also have to find a tool that will cleanly slice the alginate but not cut your skin. Before you cut seams, mark alingment lines across the cut line so you can get it back together properly.You might be lucky and be able to peel it all off in one go, you never know. You can press a layer of fabric into the outer surface of the alginate as it dries to give it more strength. You then have to make the mould reform as close as possible to the right shape (the thicker the layer around your head is, the better it will hold its shape) and cast a plaster interpositive into it. Before casting, check the seam is aligned inside and if it looks very bad use wig tape or something to hold it together. Don't cast in one go, start with an even coating washed over the inside and then slowly build it up in layers and fill it. Peel the alginate off once the plaster has gone off (the mould will probably be destroyed) and look yourself in the face for the first time. The interpositive, or plug, will need some work to repair damage and tune the edges and give it all a little fine definition. Build up with plaster or clay and scrape and cut away with fine tools. You should not clear out the nostrils or anything, if you do the mask will have little plugs that lock into your nose and which will drive you crazy. Leave the nostrils, ear canals and things raised on the plug so the mask will have an opening there. Cast your mask onto this interpositive plug and scuplt it.
That's how I'd do it anyway, might be completely wrong!
Posted 14 September 2011 - 08:13 PM
Posted 16 September 2011 - 04:20 PM
want to make one that fits perfectly to my face and moves with my expressions, so i need to find myself an art student then lol
Posted 16 September 2011 - 04:25 PM
Posted 16 September 2011 - 07:26 PM
Posted 17 September 2011 - 07:35 PM
Posted 17 September 2011 - 08:40 PM
Posted 17 September 2011 - 08:46 PM
