Replacement Radiator
6 replies to this topic
#1 _mini1000_
_mini1000_
  • 236 posts
Posted 14 September 2011 - 10:40 PM
hi guys
im after a new replacement radiator for the mini
the engine is a 998 which has a few mods such as a cam, head, exhaust, inlet etc
was looking at a minispares 3 core radiator or an upgraded core from a local radiator firm (works out £20 dearer)
my question is would a 3 core be fit for anything other than a standard engine?
i cant stretch the budget to a two core rad so it has to be either the 3 core or a recore
thanks
#2 jaydee
jaydee
  • 8,565 posts
Posted 14 September 2011 - 10:50 PM
Heard good thing about 2 core rads and especially the bigger alloy rads.
I use the 3 core on the rally car, and i have no electric fan,no issue at all.
The 3 core was fitted to cooper s cars by the way, it should be good enough for a small bore..
#3 maggies_minder
maggies_minder
    TMFs New official Spamster
  • 4,393 posts
Posted 15 September 2011 - 08:39 AM
i bought a 3core rad from minispares the week before last it come in at under £50.
#4 MRA
MRA
  • 7,607 posts
Posted 15 September 2011 - 11:31 AM
You don't need anything other than a standard radiator for the power that you have, the biggest mistake and yes I have seen "so called" experts do thias well is to fit the fan the wrong way around :(
#5 _mini1000_
_mini1000_
  • 236 posts
Posted 17 September 2011 - 08:51 PM
thanks
the car was overheating before we stripped the engine for a rebuild. i never got to check the old thermostat so hopefully with a new thermostat and a radiator flush it should be fit for the job.
just out of interest what temperature of thermostat would you recommend?
ive been told its better to get a hotter one as the fuel burns better? but surly wouldnt a colder one help with engine cooling?
what do you think of it in comparrison to a standard rad?
#6 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 17 September 2011 - 09:25 PM
Probably one of the best rads you can get, before you spend mega money on an expensive alloy rad, is the Mini Spares 2 core rad. A lot of people and I mean a lot of people are using it. However as MRA has said a fully functional standard rad should be more than enough for your spec?
#7 jaydee
jaydee
  • 8,565 posts
Posted 18 September 2011 - 09:28 AM
Correct, get a 88° thermostat for a modified engine (yousaid you have cam, head, etc..) because unleaded fuel needs higher temperatures to work properly.
A colder thermostat wont aid cooling, just make the warm up time longer, and if you have a cooling problem, the car will overheat with whatever thermostat you got.
