Boring out a 1275cc Pros and Cons
Posted 30 January 2006 - 09:22 PM
I know a guy who can do this. What I need to know are the pros and cons to this. Obviously pros = power. So what cons are there, are there problems with the headgasket, cylinder head? Any other problems that may occour?
Will an insurer even notice an engine re-bore I'm going to declare almost everything, but if I can get away with it I will.
I want to keep it at the standard stroke which is 81.28mm but I'm not sure on how far to take the bore. 73.50mm would take it to 1379cc would this be too much? Or should I keep it to something more modest like 71.67mm 1312cc.
I know I'm going to have to replace the pistons to fit the new bore. Will anything else need to be replaced. Any mods need to be done to the cylinder head or gasket. I'm really not too sure if I should go ahead with this. This mini is running as standard atm, but will be reciving a stage 1 kit, induction kit and new suspension.
Can someone shed some light so I can just ask my mate to take it away and do it?
Kyle
Posted 30 January 2006 - 10:47 PM
If your keeping the standard head, but fitting an uprated cam I'd say you'd be fine with 1380cc. If your considering a modified head and a fairly wild cam then you get to the limit fairly easily and if you are not carefull melt the engine. There is an option to increase the size of the injector, but this is still at the experimental stage. Best bet is a Rover 100 K8 or K16 1.4litre SPI injector, the whole thing apart from the manifold is a direct swap. But the results are unknown.
Cooper S packs consist of a modified head, 1.5:1 ratio rockers, lcb, modified inlet and takes it to 82bhp, to give you an idea
I'm doing this but to 1399cc with an MG Metro cam. I have already sourced a bigger injector and running this as we speak on a test baisis on the standard engine. Keeping the standard head is restrictive but with the extra cubes it should produce a lot more torque lower down the revs, the head strangling it higher up the revs. I t more of a test, research and development, to see what the results are, I'm not after every last bit of power, just cheep. Im just waiting on the piston rings being delivered.
Edited by Mini Sprocket, 30 January 2006 - 10:50 PM.
Posted 01 February 2006 - 07:45 AM
I 'm not sure that I want to change the SPi, do you think 1330 would be alright with the standard SPi.
Planning on getting better fuel pump, regulator, SU throttle body and shiny radiator to keep things cool.
Questions still stand, anyone ever had problems other than the SPi not keeping up with over boring?
Will the insurer notice an over bore? All other mods are going to be declared.
So I've worked out the standard head should be fine for a 1330, but what about the head gasket? Should I invest in a quailty one while I'm there?
Shall I go for cheaper pistons around £250 for a set of 4, or should I go more expensive. Is it worth getting a good set? Or will £250 's worth be fine?
Posted 01 February 2006 - 05:09 PM
Headgasket wise, I use the Payen BK450 gaskets on my 1330 and have no problems at all.
Piston wise if going for 1330 or std overbore sie that the Hepolite 21253 pistons are great little pistons and are readily available!
Posted 01 February 2006 - 05:16 PM
beks or tarks might be able to help :wink:
Posted 01 February 2006 - 07:32 PM
just a thought: does it actually *need* a rebore??
TTFN,
Dave
Posted 01 February 2006 - 09:06 PM
To be honest it dosn't actually need a rebore, but the thing is it seems to be an easy power gain. I can get the re-bore done on the cheap, so thats a bonus.
Posted 01 February 2006 - 09:46 PM
Have a look around here, just seen this place in Mini World CLICKY HERE MUN
Posted 01 February 2006 - 11:40 PM
if you have bigger bores but you dont increase the volumetric efficiency of the head then you wont release the benefit of the bigger bores
Would suggest (as the bottom end is sound) get a decent cylinder head first as this will be cheaper than new (decent) pistons and the work involved in stripping it all down to actually do the rebore..
TTFN,
Dave
Posted 02 February 2006 - 11:28 AM
Posted 02 February 2006 - 01:27 PM
my point above was based on whats been said by : basically - 'i can get the rebore done cheap' as its "easy power gain", etc
Posted 02 February 2006 - 05:48 PM
