So I took everything apart to degrease, clean and refurb and now I've come to the putting them back together stage.
The pot joints went to plan.. they are in and ready to be re-greased and have the rubber cup fastened down (after they've been passed through the subframe) but I'd like someone to double check to make sure the bearing cage is facing the right way, the tapered end should face towards the pot joint, as far as I'm aware.
It all sits in without the bearings..
But add the bearings (this is the other side hence why the middle part (unsure of the name) has a different step to it.
There is no way in hell that will tap in with a rubber mallet..
Am I missing a trick? I've been swearing at it for long enough now!
