Cooling Fan
Posted 26 September 2011 - 09:25 AM
Just had the head off my 1275 metro engine re-vamped, i had the yellow cooling fan the wrong way so as the engine was down i decided to turn it around, bingo sorted ha ha when i fitted it i made sure it was missing the crankcase breather but on starting the engine WOW yellow bits everywhere, so i changed my boxers ughhhhhhhhh the blades must have bent when it fired up anybody any idea how many spacers i need to stop the fan deflecting and smashing again or should i get a different kind of cooling fan
Posted 26 September 2011 - 09:44 AM
Posted 26 September 2011 - 10:02 AM
Posted 26 September 2011 - 10:18 AM
Posted 26 September 2011 - 10:48 AM
when you put it in, did you spin it to check that it wasnt going to hit? ive just replaced my rad and had to go from 2 spacers 2 one to ensure it didnt hit the rad!
Yeah bud i set the tappets with the fan the right way around i have put in one spacer, just checked and i can get my fingers between the fan and the rad so it will take another one what i did forget to mention it was hitting the crank pully as well seems odd to me just wondering if the fan has disstorted due to overheat ect hopefull a hammer new fan and an extra spacer may solve i did take a 998 engine out have i overlooked something
Posted 29 September 2011 - 09:52 PM
Posted 29 September 2011 - 10:55 PM
If you rocker pads are worn out replace or repair, don't attempt to bodge it to make it work ok
Posted 30 September 2011 - 06:45 AM
Posted 30 September 2011 - 06:54 AM
CLASSIC!!!!!You own a Mini and you sold your welder ??? ....
Posted 30 September 2011 - 10:17 AM
Posted 30 September 2011 - 04:23 PM
