Top Rail Of Drivers Door
5 replies to this topic
#1 karl 93
karl 93
  • 86 posts
Posted 26 September 2011 - 07:18 PM
just wondering if you can buy the top bit of the door that goes around the window as mine has cracked and rusted where it joins the main door skin.
If you can buy it does anybody know the name of it so that I can find a replacement??
Karl
#2 Se7enS1ns
Se7enS1ns
  • 472 posts
Posted 26 September 2011 - 07:23 PM
I think you're referring to the actual door frame itself, in which case, yes and no. Yes you can buy a new door frame, but no you cant just buy the window frame section by itself - unless someone makes a repair panel that I'm not aware of.
Best option: Have someone weld the crack up, then adjust the door latch - cracked frames are usually caused by the window frame coming into contact with the door rubber before the latch closes fully, causing the frame to flex.
Dan
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,091 posts
  • Name: Neil
Posted 26 September 2011 - 07:35 PM
If its badly rusted then you will need to find a section of window frame and insert a new piece very much like i did on Project Erm.
#4 R1minimagic
R1minimagic
  • 4,660 posts
Posted 26 September 2011 - 07:46 PM
I have a door which is scrap on the bottom edge but can cut the frame out if you want it, depends which side it is?!
#5 karl 93
karl 93
  • 86 posts
Posted 26 September 2011 - 08:15 PM
will definately be looking at that :) thanks
and R1minimagic its the drivers side door..... ideally need the whole frame around the window as it is badly rusted on both sides
Thanks for the replies :)
#6 sonikk4
sonikk4
  • 16,091 posts
  • Name: Neil
Posted 26 September 2011 - 08:23 PM
The biggest problem with trying to replace the whole frame is its embedded into the door and will take some getting out. However if you have a look at the Project Erm link you can see where i made a couple of guides to clamp the frame to together whilst i added the insert sections to make the doors fit the cut outs better.
