Carb For 998Cc Mini Thirty
7 replies to this topic
#1 skinkb
skinkb
    Starting My Mini Up
  • 4 posts
Posted 27 September 2011 - 08:36 PM
Hi
Does anybody know where I could get a carb for my 998cc Mini Thirty. According to the garage that has MOT'd the car, the carb that is currently on it is for a 1800-2000cc.
I've had a look on Minispares but as i'm not exactly a mechanic, they kind of all look the same to me!
Thanks!
#2 matt615
matt615
  • 923 posts
Posted 27 September 2011 - 08:48 PM
This is the type of carb a Mini 30 would have as standard:
https://minispares.c...pid=35873=
But you can probably find a second hand one much cheaper.
What carb do you currently have fitted though? Not sure if the garage knows what they are talking about if they think it's from a 2000cc car.
At the end of the day, if your car is running ok then why bother changing it?
#3 danny19boy86
danny19boy86
  • 298 posts
  • Local Club: m4 minis
Posted 27 September 2011 - 08:53 PM
hs4 is the standard carb for 998 but you can put a hif38 for better performance
#4 lil3on
lil3on
  • 379 posts
Posted 27 September 2011 - 09:23 PM
http://www.minisport...nfo_MS2902.html
a mate of mine is using that on his 998 :)
hope that helps
Edited by lil3on, 27 September 2011 - 09:26 PM.
#5 bmcecosse
bmcecosse
  • 9,699 posts
Posted 27 September 2011 - 10:28 PM
Has it failed MOT on emissions ? HIF 38 will be the carb to use on a standard 998.
Edited by bmcecosse, 27 September 2011 - 10:29 PM.
#6 jaydee
jaydee
  • 8,565 posts
Posted 27 September 2011 - 10:29 PM
Please before spending silly money just becuse the MOT told you some BS, post a pic of the carb you have..
#7 Brams96
Brams96
  • 2,308 posts
Posted 28 September 2011 - 06:01 AM
I dont know how they know your carb is for a 1800-2000cc engine as that would have to be at least an HS8 which is far too big for a 998 & it would run like 5H1T. Can you give us the number on the little alloy tag on the carb (if it has one)? If not then you'll need to measure the air inlet size:
HS2 = 1.25"(32mm),
HS4(or HIF38) = 1.5" (38mm)
HS6(or HIF44) = 1.75" (44mm),
HS8 = 2" (50.8mm)
You'll need to remove the air filter, if its a standard filter box undo the two top wing nuts & lift off the box then you can undo the two screws holding the elbow on & measure the face of that. If it's a Kn'N type remove it and try to measure the face of the carb.
Here's a couple of sites with some Carb info which makes interesting reading:
http://www.mgbmga.com/tech/mgb19.htm
[img]http://www.sw-em.com/SU_vs_disp.jpg[/omg]
If you do have the wrong carb I have a spare HS4 carb I could sell you, PM me to let me know if you need it.
#8 skinkb
skinkb
    Starting My Mini Up
  • 4 posts
Posted 28 September 2011 - 07:50 AM
Thanks everyone for replying. It did fail it's MOT on emissions but also needed some welding doing. We tried getting it running before the MOT and it was running really badly, was fine on the straight and flat but as soon as it hit any incline the engine would cut out regardless of how much rev you gave it.
I'll find out from the garage what carb is currently on it as it's still with them.
Thanks Brams96, i may well be in touch!
