Bedding The Engine In
12 replies to this topic
#1 liam1288
liam1288
  • 602 posts
Posted 29 September 2011 - 12:33 AM
Hi guys, just installed a rebuilt engine that I bought and just wanting to know tips on and whats the general consensus on how to bed an engine in... How to drive, milage, oil change...
Also once bedded in, will I feel a difference? Smoother ride/sound?
#2 Ethel
  • 26,088 posts
Posted 29 September 2011 - 12:41 AM
You will very likely get some conflicting opinions.
I'll start the controversy rolling by suggesting you should drive it as hard as you like, but keep the revs down for the first few hundred miles. The main aim is to bed in the piston rings, which requires some pressure in the cylinders. Don't use any super fancy oils for the same reason.
#3 Tommyboy12
Tommyboy12
  • 2,255 posts
Posted 29 September 2011 - 02:27 AM
I would personally drive it normally but dont go too mad on the revs. Use a reasonable quality oil so as to get decent initial lubrication. Build up the revs slowly over the first thousand or so miles.
#4 Frisco
Frisco
  • 417 posts
Posted 29 September 2011 - 06:24 AM
Avoid max revs and idle. It needs pressure so drive it hard enough while varing the revs.
I personally change the oil after 10 miles, 100 miles with cheapo stuff and at 500 miles over to decent stuff. After that it should be done
Whatever you do dont leave it sitting at idle in the garage on first startup
Edited by Frisco, 29 September 2011 - 06:26 AM.
#5 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 29 September 2011 - 06:25 AM
hmmm. as Ethel says,very much open verdict,never has been a definate answer on this one. Heres a site thats worth a look. www.mototuneusa.com/break_in_secrets.htm
#6 liam1288
liam1288
  • 602 posts
Posted 29 September 2011 - 08:42 AM
Cheers guys! And would I feel a difference in the drive once fully bedded in?
#7 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 29 September 2011 - 09:09 AM
BUT...
if it has had a new camshaft this needs to be bedded in first:
This means that you have to leave the car running at 2000rpm for 20 minutes. After this is done follow the above advice
#8 jaydee
jaydee
  • 8,565 posts
Posted 29 September 2011 - 09:11 AM
You'll see that during the bed in the engine will lack of performance and burn some oil, i've also had to change the air/fuel ratio a couple of times..
When bedding in the engine also avoid too ruch mixture like a plauge, because bore wash is very dangerous for an engine during the piston ring bed in process.
#9 joshafee
joshafee
  • 14 posts
Posted 29 September 2011 - 09:31 AM
change all oils arfter every 1000 miles top up oils arfter all drives get an engin flush
dont know what uve got to do this but get an eobd disnostic scan for ecu cheak for falts :proud: :proud: :gimme:
#10 joshafee
joshafee
  • 14 posts
Posted 29 September 2011 - 09:33 AM
and if it sitting in ur garage for a week start it up for 25 mins :)
#11 joshafee
joshafee
  • 14 posts
Posted 29 September 2011 - 09:36 AM
if it runs good go to a place of mot get the imissions testid just to be safe then de cat it sounds better
#12 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 29 September 2011 - 04:48 PM
the mototune way of running in is great, i've ran in literally hundreds of engines over the years that way.
if you can, try and do the run in all on the same day. nothing more fun than blasting up and down country lanes for the day ;)
... get an engin flush
two terrible bits of advice there ;)
never use a flush and don't let an engine sit idling, it needs pressure to seal the rings.
Edited by ANON, 29 September 2011 - 04:51 PM.
#13 Ethel
  • 26,088 posts
Posted 30 September 2011 - 10:32 AM
Idling engines also take longer to get up to the temperature where the oil is designed to work so it's always better to drive straight off, but go easy on the revs until you get to running temperature.
Engine flush has its place, but it's not in newly built engines,which should have been thoroughly cleaned before they were put back together. An oil filter is all you need to protect your new bearings.
