As above rearly,
I need to remove three diff bearings and refit two?
As i have two diff's one with 3.44 (with two bearings) and a 2.95 diff with one bearing which i want to use the two off the 3.44 and put on.
Cheers.
Best Way To Remove A Diff Bearing And To Refit?
Nicks217
, Oct 02 2011 10:21 PM
4 replies to this topic
Posted 02 October 2011 - 10:21 PM
Posted 04 October 2011 - 12:17 AM
You will need to buy or borrow a puller set. Sykes Pickavant do a good mixed set and would probably recommend the puller which fits around the whole of the outer race to minimise potential damage to the bearing. To be honest, your best bet would be to invest in 2 new diff bearings (£23 ex vat - minispares) and then, you will not have to worry if you damage a bearing removing it.
Posted 04 October 2011 - 05:53 AM
i used tyre leavers .. cam off really easy .. but i was changing them for new ones anyway .. but i could of reused them if i needed
Posted 04 October 2011 - 07:21 AM
The best method of removing them is with a puller of the following design...
http://www.machinema...-bearing puller
Posted 06 October 2011 - 12:07 AM
Exactly the one I was trying to describe.
