Cam A Oil Pump Be Changed With The Engine In The Car?
Posted 03 October 2011 - 07:26 PM
or is it easier to pull the engine out.
second thing the main clutch seal, easier to put on when putting the cover on, or after the cover is in place,
thanks for you help steve
Posted 03 October 2011 - 07:52 PM
hmm thinking about it you should be able to do it with the engine in as youve got a flip front that should help quite abit
Posted 03 October 2011 - 07:55 PM
It is possible to fit oil pump with engine in car but i would remove the engine as it would be much easier and cleaner and you would have to remove one of the engine mounts and support the engine while you worked on it
.Bear also in mind that when stripping engine down to this stage (gears and bearings exposed ) you need to be very scrupulously clean when reassembling and having the engine still mounted its easy to contaminate the area .
So ............... Take the engine out !
I have fitted the main clutch oil seal when reassembling and in situ ,the seal is easier to fit to the cover first then refit cover BUT you must be very very careful not to damage the oil seal lips or dislodge the tensioner spring as you slide it over the splines . i use insulation tape and a smear of grease to help , dont forget the plastic oil seal cover /oil flinger afer you fit the oil seal .
Buy a good quality oil seal ,if it starts leaking its a big job to change it for the sake of a few quid .
Posted 03 October 2011 - 08:01 PM
prob take it out again lol.
thanks for the advice
Posted 03 October 2011 - 11:07 PM
Posted 19 December 2011 - 04:39 PM
I've got no oil pressure, what could be the cause of this? ie what would it temporarily mask?If yo uare fitting a replacement pump, then I will assume that it is because you have no oil pressure..... in which case the chances are that you will NOT fix the issue just mask it for a short period
Edited by KJM, 19 December 2011 - 04:41 PM.
Posted 19 December 2011 - 07:17 PM
Posted 19 December 2011 - 07:35 PM
Posted 20 December 2011 - 03:36 PM
Posted 20 December 2011 - 04:37 PM
Posted 21 December 2011 - 11:14 AM
Posted 21 December 2011 - 11:53 AM
