Indicators And Wipers Not Working
Jumpinjacks
, Oct 03 2011 10:12 PM
8 replies to this topic
Posted 03 October 2011 - 10:12 PM
My friends mini's indicators and wipers dont work anymore, the hazards work fine. We have checked every fuse we could find and they are all fine, we have tried my flasher unit in his and that didn't work, we have also looked for any loose wires, but can't seem to find anything. I am absolutely rubbish with electrics and have a Haynes manual but can not make head nor tail of the wiring diagrams lol.
Anybody got any ideas?
Posted 03 October 2011 - 10:43 PM
hi, is the wipers switch on the steering column?
if so i'd check the wires and that the connectors are fully pushed on, the connectors are usually close to the bottom of the steering column
thanks
thanks
Posted 04 October 2011 - 10:00 AM
Just a daft thing might be worth checking, on my re-build all electrics were working fine, one day switched her on and all the electics had gone to pot i found out that the reversing switch wiring had burned out and was shorting out on the exhaust might be worth a look
Posted 04 October 2011 - 10:11 AM
All wires look fine at the steering column, I will have a look to see if any wires are shorting out on the exhaust later
Posted 04 October 2011 - 01:42 PM
If you are still having problems let me know the year of the car and the model engine type points or electrnic ignition and i will have a look at the wiring diagram for youAll wires look fine at the steering column, I will have a look to see if any wires are shorting out on the exhaust later
Posted 04 October 2011 - 01:47 PM
Its a J reg, not 100% sure what year that is, 1992 I guess Mini city 998 engine points ignition.
Thanks.
Thanks.
Posted 04 October 2011 - 02:48 PM
there is a black wire on the wiper motor that goes to earth
a light green and orange goes to contact 5/6 in the fuse box, light green and white dissapears into the starter relay and ignition switch
the only common thing that i can see connecting the wipers and indicators is a couple of in-line fuses
one has purple and orange wire in one side and brown on the other which comes out of the starter relay the purple and orange goes to the hazard warning light which should have 2 wires the other is light green and purple going to the hazard switch there is green and white going to your side repeaters so first off i would find and check all in-line fuse holders there should be 4 number
Posted 04 October 2011 - 04:37 PM
Thanks for that firefox, your a legend
We have got the indicators working now, it turns out that the connectors inside the fuse case were corroded. The wipers still dont work, but I believe this could be the motor as you can here it click inside the motor but not actually work
Posted 04 October 2011 - 04:45 PM
Could be the earth or take the motor off and clean it with electrical contact cleaner
make sure it is all dry before you put it back on orrrrrrrr boooooooooooom get it at halfords
brilliant stuff
brilliant stuff
