Mk1 Grille
7 replies to this topic
#1 JackM
JackM
  • 291 posts
  • Local Club: Cyprus Mini Club
Posted 05 October 2011 - 08:09 PM
Hello.
I have a 1977 Mini and I would like to know how I could change my grille to the MK1 one! Do I need to modify anything? Sorry for the stupid question but I did not considered it before and now I see that my Mini really needs it.
Jack
#2 Mini_Magic
Mini_Magic
  • 5,747 posts
Posted 05 October 2011 - 08:17 PM
You will need to cut off the lip on the bonnet, or drill out the weld spots to remove it.
Might have to drill a couple of new screw holes for the Mk1 grille as well.
#3 redhot-mini
redhot-mini
  • Just Joined
  • 537 posts
  • Local Club: North Devon Mini Register
Posted 05 October 2011 - 08:19 PM
to put a mk1 grill on your mini it will just bolt on but with the moustashe you will have 2 grind off or drill of the spot welds on the lip on your bonnet
#4 JackM
JackM
  • 291 posts
Posted 05 October 2011 - 08:25 PM
my bonnet is a fibreglass one! Will this be the same?
#5 redhot-mini
redhot-mini
  • Just Joined
  • 537 posts
Posted 05 October 2011 - 08:35 PM
you will have to cut the fiberglass lip off then you might need to filler the edge if it gets damaged cutting it off not shore how well it will work as only done it with metal bonnets
#6 JackM
JackM
  • 291 posts
Posted 05 October 2011 - 09:36 PM
ok then! thanks! I will try and see! its worth it!
#7 redhot-mini
redhot-mini
  • Just Joined
  • 537 posts
Posted 06 October 2011 - 08:04 PM
it is i done mine and it changes the hole look of the car i love mine
#8 MiniMonty
MiniMonty
  • 1,802 posts
Posted 09 October 2011 - 01:15 AM
If you do it let me know - I've got an original MK1 "moustache" that's looking for a new home.
The MK1 front end was MUCH prettier IMHO....
Best wishes
Monty
