Hi everybody,
just a quick one, i'm looking for an alternative engine earth strap location, as the current one on the upper stabiliser has rusted on, and im looking for a good alterantive place to put it as the current one has nearly snapped.
This is obviously a temp fix until i can remove the stabiliser bolt.
Any suggestions are welcome and the earth strap is a standard length one.
Thanks, Jake
Alternative Engine Earth Strap Location
jakejakejake1
, Oct 06 2011 01:54 PM
5 replies to this topic
Posted 06 October 2011 - 01:54 PM
Posted 06 October 2011 - 04:57 PM
It should be able to reach the slam panel. I've got a second one from the engine to slam panel and its standard length.
Posted 06 October 2011 - 06:34 PM
With a long enough cable you could whack it anywhere on the body.
Posted 06 October 2011 - 06:50 PM
Mine used to be bolted to the transmission bellhousing beneath the coil, and ran to the earth point behind the washer bottle.
Posted 06 October 2011 - 09:17 PM
The early minis used to have the earth cable from a bolt on the clutch casing to the inner drivers wing....do not make it to long as this will be inefficient....max 6"- 8" .............
Posted 06 October 2011 - 09:22 PM
I needed to replace one on my car, and I went from my clutch housing, in the access hole, to the phillips screw with a few other earth cables on. This is on the bulkhead, but may be different on yours as mine is pre servo
