Cylinder Compression For Newly Built 850Cc Engine
5 replies to this topic
#1 mk=john
mk=john
  • 1,167 posts
  • Local Club: Milton Keynes Mini Club, Mini Cooper Register
Posted 08 October 2011 - 04:08 PM
Hi
As many of you are aware, I have had my 850cc engine rebuilt to original spec for my 1960 mini. I previously had low cylinder compression results, and the cylinder head has been rebuilt again because of this.The new results are using the Gunson compression tester:
Cylinder#1: 100 PSI
Cylinder#2: 118 PSI
Cylinder#3: 100 PSI
Cylinder#4: 100 PSI
The engine has not yet been started since rebuild, so i guess these values will improve as the rings bed in?
But are the values shown, high enough for the engine to start in the first place?
John
#2 mk=john
mk=john
  • 1,167 posts
Posted 09 October 2011 - 08:20 AM
Anyone...please?!!
#3 yellowmonster
yellowmonster
  • 170 posts
  • Local Club: MOCT
Posted 09 October 2011 - 10:52 AM
As you already mentioned yourself John; the parts need setting/ bedding in.
The values are good enough to get the engine started, and will probably rise as the miles pile up.
Take care
#4 midridge2
midridge2
  • 1,794 posts
Posted 09 October 2011 - 10:53 AM
yes the engine should start with those readings if all other things are ok, eg timing/fuel etc.
those are very low readings for a rebuilt engine. was it rebored or just new rings fitted?
#5 mk=john
mk=john
  • 1,167 posts
Posted 09 October 2011 - 11:25 AM
Fully rebuilt
#6 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 09 October 2011 - 12:13 PM
put a little oil in each cylinder if the values increase a lot then you know that its a ring issue, that may just require simply bedding in. If the figures do not increase you know the valves or head gasket are not right!
