I have a 1976 mini 1000, I want to wire the key start to the relay, and then to the solenoid,who can help me.
Connect Solenoid To Relay And Key Start
Xiaharry
, Oct 11 2011 04:47 AM
6 replies to this topic
Posted 11 October 2011 - 04:47 AM
Posted 11 October 2011 - 05:18 AM
4 pin relay
Don't worry about the descriptions on this diagram its the pins your interested in
Pin 30 Power in, take a feed straight off your solenoid battery terminal
Pin 85 earth, connect to car body somewhere
Pin 87 This goes to were the white/red wire went on your original solenoid
Pin 86 plug the white/red wire off the solenoid onto here.
Edited by lrostoke, 11 October 2011 - 05:19 AM.
Posted 11 October 2011 - 06:07 AM
Thank you. But
Is the 87 connect to the small connecter of solenoid (the solenoid has three connect points, one bigger to battery, another one to starter, and one smaller to 87?)
86 connect to?
Thanks again
86 connect to?
Thanks again
Posted 11 October 2011 - 06:31 AM
here's news,the key start has 4 connect points(bat,acc,ing,st)
Posted 11 October 2011 - 08:36 AM
I'm a little lost why you are putting a relay in ??? The original loom doesn't use a relay.
On your loom I'm assuming you have a loom, there will be a white/red wire that comes off the ignition, this connects to Pin 86
But on a standard loom of your year it would just connect direct to the small spade terminal on the solenoid.
Posted 12 October 2011 - 03:15 AM
thanks man,you remind me !!!
Posted 12 October 2011 - 03:34 AM
Oh wooooooow, thank irostoke, I just start my mini, I can't wait to drive to work
