Subframe Info For My Mk1
Posted 11 October 2011 - 03:51 PM
I'm just seeking clarification on the front and rear subframes for my mk1 mini 850 1967. I've looked under frequently asked questions and I can only find auto and manual queries.
I have a mk1 mini and both subframes are pretty bad. I want to replace them and build the new ones up so I can just swap them over when I replace the engine and brakes.
The plan is to replace the hydrolastic with dry suspension and fit disc brakes to the front with a 1380 motor.
Am I right in thinking as long as i get both the later dry suframes front and back they will fit my mk1 with my suspension plans?
Kris
Posted 11 October 2011 - 04:51 PM
Bear in mind that the new type will need the rubber mountings that will be missing from the originals, and also that the tower bolts will be different.
Just been looking at your project thread. Looks like you have a similar collection of rust as me!
Posted 11 October 2011 - 05:25 PM
I converted my Mk2 to dry but used a Mk1 dry front subframe. I used a much later rear subframe c1995 without any problems.
Posted 11 October 2011 - 05:59 PM
Kris
Posted 11 October 2011 - 06:23 PM
The hydrolastic subby will not accomodate the rubber cones correctly.
You will also need different upper arms for the front
Posted 11 October 2011 - 06:25 PM
The tower fittings on the Mk.1 have two long bolts each side, the rear fittings on the front frame are fitted at the 'kick' line of the floor with 2 off 5/16" UNF bolts and nuts per side and don't cause the panel fatigue failure from which the later cars can suffer. The front fittings are just bolts and nuts with no rear-drop fitting.
Posted 11 October 2011 - 06:35 PM
http://www.m-machine.co.uk/
http://www.minimail.co.uk/
they have a huge mk1 spares stock...................
Posted 11 October 2011 - 06:47 PM
Kris
Posted 11 October 2011 - 07:09 PM
If you have a hydro front frame you just knock back the hydro locating tabs which are up in the tower, or grind the tabs away so that the rubber cone springs will seat correctly. There is a 1/4" spacer at the tower top to body cross-member position on the hydro cars. Keep this if using a modified hydro sub-frame, but delete it if using an original 'dry' frame.
Edited by Cooperman, 11 October 2011 - 07:10 PM.
Posted 11 October 2011 - 07:10 PM
The early front subframe is significantly different to the latter type - I think Nick at Mini Bitz in Sheffield will be ale to sort you out.
The latter subframe does fit and I use them as a temporary install to enable me to move the shells around while the correct subframe is being refurb. It shouldnt be used on a permanent basis as it will not fix at the rear correctly - the early sub-frames are solid mounted.
On the rear I you can get them without the mountings for the latter style exhaust - you do not need the very latest type of rear subframe
As also mentioned, you should also consider changing the front top arms for dry ones - if you the Hydro arms the steering will be quite heavy.
At the rear, the radius arm/handbrake quadrant and handbrake cables are different between hydro and dry cars. If possible, you should try and make sure that you use either all dry or all wet components - ideally all dry.
Posted 11 October 2011 - 07:21 PM
Posted 11 October 2011 - 08:59 PM
There really is no big issue with making any Mk.1 into a dry suspension car. I always do it on historic rally cars for reliability and serviceability.
Just get a Mk.1 sub-frame, dry or hydro, take a good look at it, then come back on here for sub-assembly and installation advice.
Posted 11 October 2011 - 09:07 PM
Posted 11 October 2011 - 10:27 PM
er ... I think this is the other way round. The dry tower needs the spacer. The wet tower is slightly taller with no need for a spacer. This also means the dry tower bolts are slightly longer. The tower bolt threads are also different between wet and dry.
Posted 11 October 2011 - 10:35 PM
