How Do I Replace A Radiator In My '55' Reg Mini Cooper? Help!
3 replies to this topic
#1 hj86
hj86
    Starting My Mini Up
  • 2 posts
Posted 11 October 2011 - 08:53 PM
My radiator has a small crack so needs replacing. We can get a decent new rad but Any advice on how to change it yourself would b great!!! Am keen not to do take more apart than we need to and have had vonflicting advice.
We've been told to take off the bumper, hoses, pan and front wheels, loosen plastic casing that rads in and pull forward ringer some leverage and wiggle it out! Is this right and what else shud b done??
My mini has a/c if that makes any difference!!
#2 summs116
summs116
  • 372 posts
  • Local Club: Mini 7 racing
Posted 11 October 2011 - 10:11 PM
ive done about 6 of these at work,
take wheels off and remove inner wheel arches off
remove front bumper (number plate screws aswell)and crash bar
remove front part of chassis legs 2 bolts underneath ethier side and slide out
pull front panel forward,drain water remove clips and wiggle out,
#3 charie t
charie t
  • 3,153 posts
Posted 12 October 2011 - 05:24 PM
Not as straight forward as a classic but what is these days. The wheels don't need to come off, but the front bumper and crash bar has to. The air con rad can be carefully eased forward to allow you enough room to get the rad out. The fan can be left in situe but needs disconnecting before attempting to take out the radiator. Draining the coolant off into a suitable container is what health and safety numpties say to do.
#4 hj86
hj86
    Starting My Mini Up
  • 2 posts
Posted 12 October 2011 - 08:18 PM
thanks for replies.So i should be able to do this on my driveway?is there any specialist tools needed?
