I'm looking to tidy up the wiring loom in my car and i'm wondering what the best thing to wrap it in would be? Just good old electricians tape or is there something a little better/neater.
Thanks in advance!
Wiring Loom Wrap
mkw
, Oct 12 2011 09:46 PM
6 replies to this topic
Posted 12 October 2011 - 09:46 PM
Posted 12 October 2011 - 09:59 PM
Loom tape is the correct thing to use, it looks like ordinary electrical tape but is not adhesive so you have to finish the ends with a bit of adhesive tape, it also gives the loom more flexibility. Do the " branches" of the main loom first, back to the main "trunk ", then do the main trunk.
The black nylon overbraid in the last post is also excellent if you can feed the wires through it.
Posted 12 October 2011 - 10:36 PM
I'm thinking of using spiral wire binding
http://www.ebay.co.u...984.m1439.l2649
so I can add / remove wires as I need
and normal tape on the joins
Posted 13 October 2011 - 08:37 AM
The spiral wrap doesn't look all that good
If you tape it be aware that as you tape it up the harness will twist in the direction of wrap and cause all manor of issues
There is a convoluted tube that is made with corresponding T's and Y pieces looks good if finished well also comes with brackets to fix it in place....
If you use just convoluted tube then you may need to overtape this is known as COT (Corregated Over Taped) just make sure that you DO NOT have wires protruding between the slit edges as it can and will cut through the wires...
Posted 13 October 2011 - 09:16 AM
Thanks for these replies, i think i'll go with the proper loom tape!
