Twin Carbs And Dyno Results
5 replies to this topic
#1 crock
crock
  • 90 posts
Posted 13 October 2011 - 05:51 AM
Working on a 1380 big valve build. Some of the parts I have are unknown to me, but I have David Anton heads, a 266 degree cam and 9.3 compression. The car was using a 44HIF and I am wondering what advantage there would be if I switched to the original Cooper twin HS4 or the Works replica twin HS6. Along the same lines, does anybody know of an online source of dyno tests that would show me the results of different engine builds? that way I could make a more informed decision about how far I want to go with modifying the motor.
#2 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 13 October 2011 - 09:40 AM
The Works minis used Twin H4 carbs and the cooper used twin HS2's
Your HIF will be fine, but if you want that retro look and noise then twin HS4's will be your best bet.
#3 Wil_h
Wil_h
  • 3,244 posts
Posted 13 October 2011 - 09:54 AM
Also, 9.3:1 is a bit low, more suitable for a turbo application. 10:1 will work much better.
#4 liirge
liirge
  • 4,097 posts
Posted 13 October 2011 - 09:59 AM
Yer I was going to mention that. The CR is appalling for a normally aspirated application
#5 crock
crock
  • 90 posts
Posted 13 October 2011 - 07:08 PM
9.3 actual measured compression is low? In California the best gas we can reliably get is the equivalent to British 95 octane. What kind of compression could I get away with using a 266 degree cam and 95 octane?
Also, are you saying that there is no real power benefit to dual carbs in this road application?
#6 liirge
liirge
  • 4,097 posts
Posted 13 October 2011 - 07:24 PM
10.5 would be the MaX
