Measurement Needed ( Sill Lip To Ground ) Stock ( Any Kind Soul )
4 replies to this topic
#1 santyclaus
santyclaus
    Starting My Mini Up
  • 3 posts
Posted 13 October 2011 - 12:33 PM
Hi , if anyone would be kind enough to help , i would be hugely grateful to those that could supply me with a few run of the mill measurements ,
just started the basis of a spaceframe build , but dont have a rolling shell with which to base ground measurements etc
# Need ride height - from ground to the lip of the sill ( needs to be a stock min )
# distance from front wheel center to front door shut line ( in a horizontal plane ) ,
Cheers - i feel its not the done thing to just start uncoiling my tape measure over somebody elses pride and joy that i might see , lol
#2 R1mini
R1mini
  • 1,387 posts
Posted 13 October 2011 - 12:45 PM
On my standard Mini cooper mpi with 12" wheels it's 8.75" at the front and 10.25" at the rear, I don't have the front door shut line gap but I have the distance from the rear quarter side panel where it joins the door step there is a small step on the sill edge and it is 52 7/8th" to the front wheel centre and 27 1/8th to the rear wheel in horizontal line
David
#3 santyclaus
santyclaus
    Starting My Mini Up
  • 3 posts
Posted 13 October 2011 - 12:49 PM
many thanks r1 , you sir are a diamond :D
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,053 posts
  • Name: Neil
Posted 13 October 2011 - 03:59 PM
Mini Clubman on 10's totally bog stock.
Sill height at front:- 10"
Sill height at rear:- 11 1/4"
Front wheel centre to very bottom of A panel rear edge:- 16". This is not the original A panel and it may be out by 1/8th".
#5 santyclaus
santyclaus
    Starting My Mini Up
  • 3 posts
Posted 13 October 2011 - 04:25 PM
Thanks sonikk4 , you guys couldnt be more helpful :gimme: - its massively appreciated !!!!
