Mini Has Flat Spots When Accelerating And Feels Like Its Holding Back
6 replies to this topic
#1 patslfc
patslfc
  • 62 posts
Posted 16 October 2011 - 01:58 AM
its a pain to start in the moring takes a bit and then runs sluggish for a bit but fine when warmed up then when accelerating it feels like it hits a flat spot and does not wont to push anymore............. piss poor up hills too if anyone could give me any tips or help would be very useful cheers
its a austin mini 1986 city e by the way :)
#2 leroy26
leroy26
  • 2,239 posts
  • Local Club: minisunleashed.com
Posted 16 October 2011 - 05:24 AM
have you checked things like plugs/ points/ condenser etc
#3 strettman
strettman
  • 241 posts
Posted 16 October 2011 - 09:29 AM
hi, try putting some more oil in the dashpot of your carb.
thanks
#4 leroy26
leroy26
  • 2,239 posts
Posted 16 October 2011 - 09:40 AM
or changing your carb needle!
#5 Ethel
  • 25,932 posts
Posted 16 October 2011 - 09:50 AM
Start with the ignition, it never hurts to clean & set the plug and points gaps. It will also take seconds to check for air leaks from split or loose hoses. How's the air filter too?
#6 bmcecosse
bmcecosse
  • 9,699 posts
Posted 16 October 2011 - 10:12 AM
Vacuum advance unit working ok? We really need you to check/reset the valve gaps then get a compression test to see the general condition of the engine . Obviously the ignition system needs to be tip top......
#7 chris1275
chris1275
  • 12 posts
Posted 22 October 2011 - 02:30 PM
youve not said what carb you have fitted. If its a normal HS carb undo the three screws on top of the float chamber and take the lid off carefully. Get an old rag and soak the petrol out from the pot and give it a wipe inside with some clean rag. Refit the lid and start up the car. It may just be crud in the carb and doing this normally clears out the debris as it forces fuel back into the chamber to fill it up. (engine will turn four of five times before it fires up again whilst the fuel finds its way back through).
If nothing else it will eliminate that as an issue. I used to get the problem with my first mini when i was a student and kept running the fuel tank low (sucks all the dregs through.......)
Good luck friend..
