Help ! Crankshaft Retaining Bolt.
14 replies to this topic
#1 feeenix14
feeenix14
  • 130 posts
Posted 16 October 2011 - 12:54 PM
Please help me,
I'm trying to replace my timing cover and a few other bits in that area, I've removed everything I can - radiator, alternator, engine mount is out the way and the engine is supported . . . . But
I have my big 34mm socket on the bolt but can't shift it, not sure if I'm trying to turn it the wrong way ? I'm trying to pull my bar down toward the front grille but I can't do it ?
Do I just need a big breaker bar and hang off it ?
Also I can't get my engine steady off to change the thermostat housing bracket do the bolts in the bulkhead have a nut on the other side or should they just undo ?
Any help appreciated
Sam
#2 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 16 October 2011 - 01:00 PM
The crankshaft pulley bolt can be very tight (100Nm / 75lbf). You will need a long bar on it yes. Has the flywheel been locked to prevent the crank from turning?
Re: engine steady - i assume this is an "ultimate steady"? If so, there may be some nuts on the underside - look up in the footwell area.
Edited by L400RAS, 16 October 2011 - 01:00 PM.
#3 bmcecosse
bmcecosse
  • 9,699 posts
Posted 16 October 2011 - 01:02 PM
The crank bolt is best undone using a 'rattle gun' - using a long bar can actually bend the crank nose slightly....... Take care!
#4 feeenix14
feeenix14
  • 130 posts
Posted 16 October 2011 - 01:42 PM
Thanks for the help.
Not sure how you lock the flywheel ? I have the car in gear and it's pretty solid ? Will that do the job ?
I'm assuming a rattle gun is the airgun they use at a garage ? I really wanted to have a go at doing this myself but it looks like I will have to put it back together and take it to a garage with my parts and ask them to sort it. Gutted.
#5 bcjames
bcjames
  • 2,729 posts
Posted 16 October 2011 - 02:02 PM
You need to take the starter out and use a screwdriver/spanner/shell/flywheel lock tool against the flywheel to stop it turning. I don't like the idea of doing it against the gear box.
#6 feeenix14
feeenix14
  • 130 posts
Posted 16 October 2011 - 02:08 PM
But won't that damage the flywheel. Break teeth off it or something ?
#7 bcjames
bcjames
  • 2,729 posts
Posted 16 October 2011 - 02:18 PM
Shouldn't do if you are careful. Rover made a tool for the job and it's in their workshop manual under this job.
#8 Frisco
Frisco
  • 417 posts
No it will be fine if you do it properly. You have to remember that the diameter of the flywheel gives it a big mechanical advantage so you wont be putting anywhere near the same force on the ring gear teeth as you are on the bolt.
#9 feeenix14
feeenix14
  • 130 posts
Posted 16 October 2011 - 03:19 PM
Done it !!!
Starter out, then I jammed a little spanner in there and pulled on that pole !! I think those extra gym sessions have paid off.
When I got the bolt off there was a washer behind there really mashed up ? Will I need to replace that when I rebuild it all ?
Thanks for the help everyone I was starting to lose my rag with it now I'm chuffed !! Anything else I should do before I take off the timing cover ? I read somewhere about a woodruff key but I can't see it at the minute ? Will I be able to see it when the timing cover is off ?
Thanks again peeps
Sam
#10 bmcecosse
bmcecosse
  • 9,699 posts
Posted 16 October 2011 - 03:25 PM
The little washer was the locking washer - you should have released it before removing the bolt. The other way to undo this bolt is to use the starter motor - good fitting socket on the bolt head and extension arm resting on the subframe - obviously IN THE DIRECTION OF ROTATION ! Then jab the starter (plug leads off).
#11 R1minimagic
R1minimagic
  • 4,660 posts
Posted 16 October 2011 - 03:31 PM
Sounds like a good way to wreck a starter motor to me!
#12 lrostoke
lrostoke
  • 6,923 posts
Posted 16 October 2011 - 04:08 PM
Done the starter motor trick on Landrovers :) works a treat, only takes a flick of the key normally
#13 feeenix14
feeenix14
  • 130 posts
Posted 16 October 2011 - 04:10 PM
I don't understand how I could have released the washer before I released the bolt ? The crankshaft bolt was holding it on against the timing cover ? Anyways it's off now.
I'm going to pack everything away and order a few gaskets that I think I should fit while I'm in there as it looks like the previous owner was a fan of silicone sealant and not proper gaskets :( then do it in one go.
Just a quick one - crankshaft bolt and timing cover bolts - does anyone know the torque figures for these when I'm doing them back up ?
Thanks again
Edited by feeenix14, 16 October 2011 - 04:11 PM.
#14 L400RAS
L400RAS
  • 2,479 posts
Posted 16 October 2011 - 04:20 PM
As I said in post #2... crankshaft pulley bolt = 100Nm / 75lbf
the others:
Timing cover and front plate:
14 in UNF bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7Nm 5lbf
516 in UNF bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16Nm 12lbf
Remember to knock down the lock tab through the inspection hole in the inner wing (under the passenger wheelarch)
Edited by L400RAS, 16 October 2011 - 04:21 PM.
#15 bmcecosse
bmcecosse
  • 9,699 posts
Posted 16 October 2011 - 04:31 PM
It works fine with the starter motor - Morris Minor owners have been doing it this way for many many years. Just need to make sure nothing can fly about - possibly wise to lay an old rug over the socket/extension in case it jumps off.
