Weber Inlet
Posted 17 October 2011 - 07:50 PM
Posted 17 October 2011 - 08:06 PM
Posted 17 October 2011 - 08:44 PM
Posted 17 October 2011 - 08:47 PM
Posted 17 October 2011 - 08:54 PM
Edited by MJWarren, 17 October 2011 - 08:55 PM.
Posted 17 October 2011 - 08:55 PM
ported
oversized valves
dubble valve springs and gasflowed
its also bored to 1380 and running some sort of cam not sure
Posted 17 October 2011 - 08:56 PM
Posted 17 October 2011 - 08:58 PM
Rob Waddington the Dyno magician said it was a good inlet manifold that flows very well even though it was offset,but it was not the dreaded swan kneck type which flows badly.
Anything longer than 4" for a road going mini to me is in the race spec department where you,re not bothered about space / air filter etc.
A good straight or slight offset short type with correct length carb ram pipes and good flowing air filter will do the job providing the webers in good nick and set up as near as possible.
Posted 17 October 2011 - 09:01 PM
Posted 17 October 2011 - 09:03 PM
Posted 17 October 2011 - 09:07 PM
I changed from a Weber 45 Dcoe to a single SU HIF44 with a torque master inlet manifold and got just a tad less bhp and torque output as the 45 and with better fuel economy as far as a 1380 is concerned and a smoother drivability.
Posted 17 October 2011 - 09:10 PM
Posted 17 October 2011 - 09:13 PM
I,ve got some pics of my 40dcoe off the car with filter and manifold connected,i,ll try to put some up.
Posted 17 October 2011 - 09:30 PM
If you,re struggling to get it set up i would think about going for an SU HIF44 on a minispares inlet manifold and an ITG megaflow sponge type filter with an MED stubstack, you,ll get it all in easy and the SU is far easier to get set up ( just one needle to size ).
Thats what i,ve got and it,s a screamer of a setup on that type of engine spec which is virtually the same as yours.
Posted 18 October 2011 - 05:39 PM
