4 Pot 7.5 Vs Cooper S 7.5 Brake Setup?
Posted 19 October 2011 - 05:26 AM
Id like to stop when I need to.
Jeff
Posted 19 October 2011 - 06:31 AM
Had you thought of going to 7.9" ( which are turned down 8.4" ) disks, or even vented.
Posted 19 October 2011 - 07:55 AM
Posted 19 October 2011 - 08:01 AM
Posted 19 October 2011 - 08:45 AM
Posted 19 October 2011 - 06:09 PM
Posted 19 October 2011 - 07:02 PM
Charlie
Posted 19 October 2011 - 07:10 PM
A fellow on this forum is selling me his 4 pots. He does historic rallying so had to revert to the standard Cooper s setup. He said the 4 pots had a considerable advantage with respect to fade.
Charlie
Posted 19 October 2011 - 07:55 PM
Anyway thank you all for your opinions. More the merrier.
Jeff
Posted 19 October 2011 - 08:07 PM
sorry to hijack . but will7.5 " 4 pots fit under original dunlop d1 10" mags
I suppose it depends on which D1's you use, I've have genuine D1's over mine, but did use a 3mm spacer just to give the calliper a little more clearance...
I would not be surprised if the modern copies are a little more difficult as they are probably not made to the same pattern nor standards.
Posted 19 October 2011 - 09:38 PM
Posted 19 October 2011 - 09:48 PM
