Engine Weight?
9 replies to this topic
#1 mk=john
mk=john
  • 1,167 posts
  • Local Club: Milton Keynes Mini Club, Mini Cooper Register
Posted 20 October 2011 - 12:43 PM
Hello All
Can anyone please tell me the approximate weight of an 850 engine block, complete with pistons, crank, camshaft and all the other stuff inside?
I am not worried about the weight of the gearbox or cylinder head,
I will be taking the engine block assembly it to a mini engine rebuilder and need to get this into my car, and wonder if it can be lifted single handedly into the boot of my Focus without having to use my engine hoist.
John
#2 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 20 October 2011 - 01:12 PM
I believe a 1275 with head/gearbox etc was 150kgs?
Not sure if that helps, but I'm sure you could lift it on your own if you're a big fella, can't you get a hand to lift it?
#3 sam7
sam7
  • 165 posts
2 people would do it :D
#4 ZKruly87
ZKruly87
  • 114 posts
  • Local Club: Mini Wips
Posted 20 October 2011 - 01:18 PM
i pulled a full 850 lump out of my buddies mini a couple years back. One person can pick it up, but i would suggest at least two people if you want to save the paintwork on your Focus.
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 20 October 2011 - 01:43 PM
Are we talking a built short block, if so, make sure you've had your weetabix and pick it up...
I'm lumping short blocks about all the time...
#6 mk=john
mk=john
  • 1,167 posts
Posted 20 October 2011 - 02:14 PM
yes, just the built up block (no cylinder head, gearbox, flywheel, transfer case, as these are all removed)
#7 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 20 October 2011 - 04:34 PM
Yeah you will pick that up no bother...unless your the guy off the mr muscle add!!...but dont do yourself an injury...get someone to help if your not sure.
#8 Spitz
Spitz
  • 1,716 posts
Posted 20 October 2011 - 04:38 PM
Block with all internals and no transmission on it would weigh about 275lb / 125kg
#9 bmcecosse
bmcecosse
  • 9,699 posts
Posted 20 October 2011 - 04:40 PM
Even I can lift the block assembly out of my Mini.....leaving the gearbox behind of course. If worried - place a wide plank/sheet of ply running into the boot - put the engine on the plank, then jack up the free end with trolley jack - then slide the engine along the now horizontal plank. Works even better if the car can be parked on a slope!
Edited by bmcecosse, 20 October 2011 - 04:41 PM.
#10 mk=john
mk=john
  • 1,167 posts
Posted 20 October 2011 - 06:28 PM
Thanks guys, I decided to use my engine hoist after all, besides thats what its for. I put a thick sheet of MDF on the boot floor, and my car has tie down loops welded on the floor. I used a ratchet strap and the engine is securely held down to large blocks of wood, giving space underneath for the crank.
Off to the rebuilder tomorrow.
John
