Can I Drill A Breather Into The Clutch Housing?
28 replies to this topic
#1 Mini1275buggy
Mini1275buggy
  • 84 posts
Posted 22 October 2011 - 08:51 AM
I have the wrong clutch housing with no breather on my 1275 , is it possible to just drill a hole?
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 22 October 2011 - 09:14 AM
Three holes in total, two which need to be tapped to 5/16" UNC for the screws or studs to hold the breather on and one big one ( about 1" diameter )
#3 Mini1275buggy
Mini1275buggy
  • 84 posts
Posted 22 October 2011 - 09:41 AM
Thanks but I don't think I wil be able to fit a standard breather can I just drill a hole and fit any pipe
#4 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 22 October 2011 - 09:45 AM
Why??
#5 liirge
liirge
  • 4,097 posts
Posted 22 October 2011 - 09:47 AM
#6 Mini1275buggy
Mini1275buggy
  • 84 posts
Posted 22 October 2011 - 09:48 AM
The space is limited, the engine is in a buggy. Must the hole be at the top or can it be anywhere on the housing?
Edited by Mini1275buggy, 22 October 2011 - 09:52 AM.
#7 Mini1275buggy
Mini1275buggy
  • 84 posts
Posted 22 October 2011 - 09:53 AM
It doesnt have that
#8 liirge
liirge
  • 4,097 posts
Well it makes sense with warm vapours rising and all...
If you had a suction type system linked to the carb you could put it on the side, but you would have to really angle it so that oil splash from the drop gears doesnt flow out through the breather system.
#9 Mini1275buggy
Mini1275buggy
  • 84 posts
Posted 22 October 2011 - 09:59 AM
Thanks, it makes sense, but can I simply drill a hole on the top of the housing and fit a pipe? Is the suction system the small pipe on the housing of the air filter?
Edited by Mini1275buggy, 22 October 2011 - 10:01 AM.
#10 liirge
liirge
  • 4,097 posts
Posted 22 October 2011 - 10:11 AM
Yer that would work! maybe take the hose into the rocker cover and then get a pipe from the rocker cover going into the carb. There is actually a connection on the side of the carb for a breather to be attached to. looks like its brass.
When I say the hole what I mean is:
Drill, and then tap the hole and put a pneumatic fixing on to it, then but the hose over the fitting and secure with a Jubilee clip.
Edited by liirge, 22 October 2011 - 10:12 AM.
#11 Mini1275buggy
Mini1275buggy
  • 84 posts
Posted 22 October 2011 - 10:22 AM
At the moment I am using the hole for the dipstick as an extra breather, if i dont more oil comes out of the rocker cover breather than usualy, will fitting this breather help with that?The oil rings are still pretty new.
Edited by Mini1275buggy, 22 October 2011 - 10:22 AM.
#12 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 22 October 2011 - 10:24 AM
No you can't just drill any hole, The breather on the transfer case needs a 'shield' on the transfer gear side of the case to stop oil going up the hole. If you have not got the blanked casting to drill and fit one, then it'll be very difficult. The breather is there to allow air flow in and out of the crank case.
If you just drill a hole then oil will be thrown through the hole by the transfer gears, and if you connect it to your carb, the vacuum will pull that oil into the carb, and you can imagine the rest...
#13 Mini1275buggy
Mini1275buggy
  • 84 posts
Posted 22 October 2011 - 10:29 AM
Will it help to put something like a can in the breather pipe to allow the oil to go back? (without connecting it to the carb)
#14 Ethel
  • 25,941 posts
Posted 22 October 2011 - 11:38 AM
Put up some photos, it'll give people a better idea. The system works by letting air in via the oil filler and sucking it out of the crankcase (where the blow by fumes are). AS GW says, there's 3 gears spinning in the transfer case so it will be plastered in oil. How about a timing chain cover breather & what's fitted to the fuel pump mounting?
You could fit a remote catch Tank, it'd be like extending the crank case, so it'd need a vent or vac pipe and ideally an oil return.
#15 bmcecosse
bmcecosse
  • 9,699 posts
Posted 22 October 2011 - 01:21 PM
Easiest is to add a breather on the rocker cover - or get an early cover which HAS a breather.
