Vin Info
Posted 22 October 2011 - 07:00 PM
thanks alex
Posted 22 October 2011 - 09:36 PM
Posted 22 October 2011 - 09:50 PM
Posted 23 October 2011 - 08:23 AM
Posted 23 October 2011 - 02:16 PM
VIN
The general format for the VIN for these cars is:
This was the start of it
SAX-XN-Y-A-D-B-B-D-######
VIN, First Three Positions (“SAX” in the above example)
= World Make Identifier.
SAX = MG-Rover
VIN, Fourth and Fifth Positions (“XN” in the above example):
XN = Mini 1300
VIN, Sixth Position (“N” in the above example):
= Class
N = Sport, Cooper, Cabriolet
V = Kensington
W = HLS, Mayfair
Y = City, Sprite
VIN, Seventh Position (“A” in the above example):
= Body type
A = 2-door saloon/sedan.
B = Cabriolet
VIN, Eighth Position (“Y” in the above example):
= Engine
D = 1300 Carb
M = 1300 Carb
X = 1300 SPi (standard compression ratio, 9.4:1)
Y = 1300 SPi (high compression ratio, 10.1:1)
Z = 1300 MPi (high compression ratio, 10.1:1)
VIN, Ninth Position (“B” in the above example):
= RHD/LHD, Transmission type, Final Drive
B = RHD, Manual, 3.105
C = RHD, Manual, 3.21
E = RHD, Manual, 2.76
K = RHD, Automatic
M = LHD, Manual, 3.105
N = LHD, Manual, 3.21
R = LHD, Manual, 2.76
Y = LHD, Automatic
VIN, Tenth Position (“B” in the above example):
= Model Change
A = 1300 Special Edition
B = 1300
VIN, Eleventh Position (“D” in the above example):
= Assembly Plant
D = Longbridge
VIN, Number positions (“######” in the above example):
= The sequential build number:
Starting with 010001
Edited by 2-alex-2, 23 October 2011 - 02:17 PM.
Posted 23 October 2011 - 09:31 PM
Edited by 2-alex-2, 23 October 2011 - 09:32 PM.
Posted 24 October 2011 - 06:35 AM
Yes, but I don't think the VIN will confirm this. Just look for the clues on the car:any one could this still be a italian job mini ?
Taken from Wikipedia:
Mini Italian Job
- Year: 1992 (October)
- Based on: Mini Mayfair
- Engine: 1275cc
- Exterior colour:
- Flame Red (COF - BLVC818)
- Metallic British Racing Green (HAM - BLVC1216)
- Diamond White (NMN - BLVC655)
- Electric Blue (NMN - BLVC655)
- Exterior trim: Body-coloured wing mirrors, white grilles, black bumpers.
- Decals/badges: Bonnet stripes, "Italian Job" badge, crossed Italian and British flag decals
- Interior: Black tweed, three-spoke steering wheel with Italian flag on steering wheel and front seats
- Equipment: Tinted glass, twin driving lamps, opening rear quarter windows
- Production: 1,000 for UK, 750 for Italy
Posted 24 October 2011 - 06:47 AM
As for the seats, Mainstream Coopers and Mini Flame / Racing uses the same "Crayons" pattern but with a little difference. The Flame/Racing seats has the Crayon pattern from the lower half of the seat's backs until the half of the seat's base as you have on your pic link. The Cooper has the Crayon pattern on the middle of the seat from top to base, the sides using black cloth without pattern.
Hope my (very unclear) answer helps....
Posted 24 October 2011 - 05:53 PM
1 its been re sprayed a blue colour(but was oatmeal green before the owner sprayed it even inside under the carpet it was still oatmeal green but no italian job colours)
2 it had plastic windows but got replaced with new glass ones so can say weather thier original or not
3 as stated before has different seat and also a glassfiber dash
4 another dought about it was i couldnt find the vin number on the chassis just on the plate which was on the drivers side inner wing not stamp in the bonnet rail
Edited by 2-alex-2, 24 October 2011 - 06:00 PM.
Posted 24 October 2011 - 06:00 PM
Posted 24 October 2011 - 06:30 PM
1. oatmeal green = not an original italian jobhey thanks for the info. well its hard to tell from the standard italian job as
2. Plastic windows? No mini had plastic windows (as standard)... all were glass
3. Glass fibre dash, ie non original.
4. Perhaps has had a replacement scuttle, not uncommon for a 1992 car
As i said earlier, the VIN will not confirm if it is a true Italian Job or not. It only tells you the info you have listed in #5. There is no sequential list available of Italian Jobs.does any one on here have a italian job mini who could tell me the start to thier one ?
Post a photo of the outside and inside on here for visual confirmation from a member, but from the sounds of it, its not going to be an I.J. - but does that matter?
Posted 24 October 2011 - 08:22 PM
alex
Edited by 2-alex-2, 24 October 2011 - 08:32 PM.
Posted 25 October 2011 - 06:32 AM
It will be brown and rusty and horrible colour. That is nothing really to worry about, perhaps a quick rad flush is required. It is not a sign of overheating.and might be more porblems as well and looked at the water in the radiator and was brown with rust so think it had also over heated at some point as well
Posted 25 October 2011 - 06:39 PM
alex
