Hi Guys! Decided recently i want a conversion done on my mini.
Ive decided i want to use the vts or gti engine in the saxo or 106 as there decent engines if they have been looked after.
One huge problem is i dont have a clue where to start!!
One thing that is quizing my is the subframe!
Do i get one made or customise the current one?
Any help will b greatly apprecaited!!
Stu!
not saying it cant be done..... but can I ask why have you choosen one of those engine? Is it because you like the VTS or GTI stigma that may come with having one of those engines in your mini? The fact it hasnt been done yet might answer that either the engines are no good in most peoples opinions, or its simply not an easy job to do as they wont fit easily (anything will fit if your willing to do the work or spend the money. Bulk heads can be moved and longer fronts can be purchased and or created)
I also know that everyone has to start somewhere, but no offence, if you dont know if it will fit, have to ask advice on "if it will fit" and you dont know where to start, you probably dont have the skill to carry out the conversion. Sorry to be so blunt.
VTEC's and TYPE R expensive to buy, but they are a proven engine with kits readily avalible.
For a cheaper option consider a Vauxhall engine? small block or big block. Again kits are readily avalible.
Or even go bike engined?
I hope you do sucseed as it would be nice to see something different, but I dont think the engine are particually great when compared to the vaux or honda which have the kits all ready to go. But like I said, it would be nice to see something different.
Good luck man!
Edited by E.L.M.O, 27 October 2011 - 03:18 PM.
