Firstly the car stereo. I have installed it using all the information I can find on this forum! (Thanks by the way!). I have connected all speakers ok, earth ok. Now.. The 12v permanent live (yellow wire) I have attached to my fusebox on the first fuse (25amp). I know it is meant to be (35amp) on first fuse and only works when first ignition is engaged, but I think the previous owner swapped the connections around so the first fuse is now constant.
I have connected the 12v ignition wire (red wire) to the 3rd fuse in the fusebox (5-6 25amp).
Now the problem is if I use the headlight flasher, the headunit will seem to restart itself and will turn back on straight away. Being limited to knowledge, I assume that the headlight flasher takes a big current and somewhat affects the current going to the headunit? I'm not sure if it is the red or yellow wire that is affected (I think yellow though) Any ideas at all?
Secondly, the rev counter. I have six wires (2xblack - earth. green - sensor. orange - illumination. 2xred live?.)
Everything is connected ok. Apart from the two reds. One allows the backlight of the rev counter so it enables me to see it. The other actually powers the rev counter (needle movement).
The one that allows the needle movement, once connected to a 12v supply will make the needle go over 8k revs and stays there? (As if someone over-revved the car and doesn't let go!) Any ideas on this one aswell?
Any help will be greatly appreciated! Cheers!
