Water Leaking Inside After Replacing Seals
17 replies to this topic
#1 miniallsort
miniallsort
  • 4,723 posts
Posted 30 October 2011 - 04:41 PM
hi guys my mini is letting in water when it rains i can see water drip marks by the door seals and water in the foot well area i really need to know where the water is leaking from any ideas as i have replaced the window seals what else is there i can do to have a water free mini
cheers
#2 jb93
jb93
  • 2,439 posts
Posted 30 October 2011 - 04:44 PM
This isn't going to be helpful, but do water free minis exist? :P
#3 bmcecosse
bmcecosse
  • 9,699 posts
Posted 30 October 2011 - 04:48 PM
Remove all carpets - sit in the car when it's raining (or have someone play a hose over the car - not squirting it AT the car) and see where the water enters...... Is it running through from the rear? Is it running down from the windscreen surround area - or from the front bulkhead area near the 'fresh air' vents?
Edited by bmcecosse, 30 October 2011 - 04:49 PM.
#4 jb93
jb93
  • 2,439 posts
Posted 30 October 2011 - 04:52 PM
Is there some stuff that you squirt in the seal during and after fitting?
#5 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,080 posts
  • Name: Neil
Posted 30 October 2011 - 06:47 PM
If its coming from your door seals see how well the door is fitting in the cut out. If the door is not sitting correctly it will miss the seal or not compress it.
I'm with bmcecosse here, remove the carpets and give the car a thorough soaking to trace the leak.
#6 miniallsort
miniallsort
  • 4,723 posts
Posted 30 October 2011 - 07:58 PM
ok thanks mate the water is coming from the corner scuttle area i think what about putting window sealant in the seals would that stop the leaking
#7 sonikk4
sonikk4
  • 16,080 posts
  • Name: Neil
Posted 30 October 2011 - 08:15 PM
If its coming from the window seal area it may pay you to whip the windscreen out and give the scuttle area a check over and its also a good time to check the seal out as well for any cracks or ageing. If there is no damage to anything then you could refit the windscreen and use some windscreen sealant as well.
#8 miniallsort
miniallsort
  • 4,723 posts
Posted 30 October 2011 - 09:51 PM
thanks
#9 bmcecosse
bmcecosse
  • 9,699 posts
Posted 30 October 2011 - 10:01 PM
Take the trim off the dash area and inspect the 'scuttle' area around the air vents....... Sadly all too often you can push your fingers through......
Edited by bmcecosse, 30 October 2011 - 10:02 PM.
#10 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 31 October 2011 - 12:19 AM
Hi,
Have you replaced the door check arm seals? Like this:
http://www.minispare...id=37298&title=
Or this:
http://www.minispare...id=38145&title=
#11 freshairmini
freshairmini
  • 1,718 posts
Posted 31 October 2011 - 11:13 AM
+1 to the check arm seals,
I had the same problems, water from door area, sorted it right out.
#12 LeaLeaCooper
LeaLeaCooper
  • 412 posts
Posted 07 December 2011 - 11:50 AM
Im having the same problem with my Mini - the doors fill with water after washing and being out in the rain. . .any ideas on how to fix it?
#13 freshairmini
freshairmini
  • 1,718 posts
Posted 07 December 2011 - 12:19 PM
you could try to fit new ones of those seal strips at the window edge, but I thought the doors had drain holes in the bottom, and let the water out?
#14 LeaLeaCooper
LeaLeaCooper
  • 412 posts
Posted 07 December 2011 - 01:10 PM
A few people have said they should. . .but these doors don't :ohno:
Someone said to drill a small hole at the bottom of each door - not sure how wise this would be.
#15 sonikk4
sonikk4
  • 16,080 posts
  • Name: Neil
Posted 07 December 2011 - 01:36 PM
Yes drill three holes, one on the middle and one at each end where the inside section starts to curve round. When your door is dry inside have a look to see if there is any rust if so you will have to deal with before you add any protection.
