Mini '72 Roadster "the Phantom"
11 replies to this topic
#1 hylsan
hylsan
  • 82 posts
  • Local Club: Mini Club Sweden
Posted 03 November 2011 - 09:54 AM
Ok, thought Id share whats happening on my latest project.
Im from south Sweden, have had Minis since late 90's but never really done any heavy TLC on my own.
A couple of years ago I found a nice project that was started on but never finished, a Roadster!
Have dremt of having one for a long time so it was perfect, all rust and major construction already done.
Plans are to get a old look, a mix of mk1 and 2, 10x6 banded steels and gloss black.
Engine-wise I think Im gonna use a 1275cc with a dellorto. Not sure tho if I should go with it or change to weber or dual SUs. Aiming to get something like 70ish BHP.
Have sent subframes for powdercoating with a couple of other stuff.
My steelies is sent away aswell for banding and powdercoating.
I got a cooper disc setup, GAZ shocks and hi-lows and a maniflow-system ordered and deliverd.
My plan is to have it up and running by may next year. :D
#2 miniman_7
miniman_7
  • 286 posts
  • Local Club: Looking...
Posted 04 November 2011 - 06:47 PM
My! Its colourful!
Good luck; looks a good project!
#3 hylsan
hylsan
  • 82 posts
Posted 10 November 2011 - 08:56 AM
Its like frankensteins monster, parts from all kinds of cars and then just sprayed to keep it from rusting :)
Ok yesterday I finnished front spit mount. My first welding so not too nice but good projekt to practice on.
#4 jagman.2003
jagman.2003
  • 1,307 posts
  • Local Club: Owner of my own club of Minis
Posted 13 November 2011 - 10:20 PM
Interesting project. Good luck.
#5 hylsan
hylsan
  • 82 posts
Posted 27 December 2011 - 11:28 AM
Have mostly been working on the spit (have had a few construction-problems). Now finally its up atleast;
Started to look at the engine aswell...Im totally newbie on this so any comments are appreciated (and I DO know the fan is mounted the wrong way :) ).
Read in the yellow bible from Vizard that this rocker might be from a A+, right?
Dellorto-carb
The idea is to take the head for a checkup and also the carb.
Looks like standard MG 1300 block and head but I havnt looked at the cam yet.
#6 billok
billok
  • 228 posts
Posted 27 December 2011 - 01:44 PM
hello, was wondering how you attached the spit to the car in the boot, and did it damage the car in anyway like conventional spits that go all the way threw the car thanks!
#7 hylsan
hylsan
  • 82 posts
Posted 30 April 2012 - 01:36 PM
long since update but sadly not much have happend...
First, about the spit..sry for missing your question.
No damage, if you are a bit careful. Just a weld just inside the boot for extra stability.
Im not gonna sandblast it so instead its hours of grinding...
and noticed more rust...
Gonna roll it over and look how it looks on that side before order floor-panels.
#8 mymini007
mymini007
  • 2,046 posts
Posted 30 April 2012 - 01:39 PM
looks like a great project, good luck with it.
#9 hylsan
hylsan
  • 82 posts
Posted 11 May 2012 - 07:10 AM
flipped it and the other side looks much better.
Also Im gonna weld up all vent-holes. Its roofless, how much more air do you need lol :)
Gonna fit a micro-heater instead of original matrix, warm air I could use tho...
...and finally, gonna square-out my rear foor. Want the rear silencer as high I can and no need of sparewheel.
Modded battery-bucket will be used as carb-housin in enginebay...perhaps, if I go weber/dellorto.
Thinking about arches...right now Im thinking group 2 extra wide with chrome lip. Looks awesome :)
They should work on 10x6 ´without spacers, right?
#10 hylsan
hylsan
  • 82 posts
Posted 16 July 2012 - 02:46 PM
Slow progress, spending the hours I can spare on grinding and welding. My first time so :)
soon ready for priming on this side, ordered some panels to replace some of the LH floor.
#11 hylsan
hylsan
  • 82 posts
Posted 30 July 2012 - 01:26 PM
Flipped the car and started cutting..
..and cutting...
#12 hylsan
hylsan
  • 82 posts
Posted 03 May 2013 - 08:18 AM
Have'nt updated in a while here, but not much have happend sadly.
When I started cutting I noticed more rust ofcourse so a new floor is soon welded on...
Also doing some TLC on the dual HS2-carbs im  thinking of using initally.
Also sent subframes and some other stuff to powdercoating.
Really hoping for it to be finnished for IMM2014 (acually hoping for this year so I can test-drive it before the trip to UK)
