Ignition Map Vault
8 replies to this topic
#1 diogoteix
diogoteix
  • 170 posts
  • Local Club: Mini Club Portugal
Posted 11 November 2011 - 05:37 PM
Hello guys,
I'd like to start a topic in which people could find some good starting points for ECU/Megajolt ignition maps.
Rules would be: you state your engine main specs (cc, cam, rockers, head, aproximate power) and a table with the ignition mapping.
Something like that :
1380cc, SW5-7, 1.5 rockers, 29mm/37mm head, 97HP
* at idle (below 1250 RPM and load = 0%), advance is automaticaly increase by 0-10º by the ECU to stabilize idle to a set value
Edited by diogoteix, 11 November 2011 - 05:48 PM.
#2 charliedurrant
charliedurrant
  • 519 posts
  • Local Club: There isn't one down my way
Posted 11 November 2011 - 05:59 PM
I think this would be good for FAQs. I know nothing about Megajolts but I assume they have an uploadable / downloadble file format. I've requested from the admins to allow Excel files to be attached to posts, it would be worth requesting to allow the file format for the megajolt to be allowed to be attached.
Charlie
#3 Bradley Gaunt
Bradley Gaunt
  • 139 posts
Posted 11 November 2011 - 06:25 PM
Awsome idea, im soon to get my megajolt setup and need a base map close to my engine spec so if anyone has a map for the following that would be great...
1380
31mm and 36mm valves
weber 45
large bore lcb
1.5 rockers
nearly forgot.. 296 cam
Edited by Bradley Gaunt, 11 November 2011 - 06:29 PM.
#4 diogoteix
diogoteix
  • 170 posts
Posted 11 November 2011 - 06:44 PM
I found a second map on the forum, but I don't know the engine specs
#5 diogoteix
diogoteix
  • 170 posts
Posted 11 November 2011 - 06:50 PM
Charlie
The advantage of putting an image is that everyone can use it, independently of the hardware. But an additional excel (or megajolt or other) file would be a nice touch. For these kind of formats we can always put a link to a down-loadable file.
FAQ is also a nice idea, maybe we can move the post once it grows to a reasonable content.
#6 charliedurrant
charliedurrant
  • 519 posts
Posted 11 November 2011 - 08:12 PM
Silly me, you can upload zip files. Every pc / mac / unix machine can handle zip files. If all the maps are contained in one zip file then it will make life a lot easier. The maps.zip attached contains a megajolt map for a standard 1275 A series Turbo. Note the megajolt files are simply text files with a different file extension .mjlt instead of .txt.
If someone wants to add a map just add it to the zip file and attach it to the reply....? That way the lastest maps are always in the last post....
Charlie
  • Attached File  Maps.zip   17.38K   28 downloads
#7 Bradley Gaunt
Bradley Gaunt
  • 139 posts
Posted 11 November 2011 - 10:37 PM
Is there a vault purely for mini engine maps? I know autosportlabs have a library but is very generic...
#8 charliedurrant
charliedurrant
  • 519 posts
Posted 11 November 2011 - 10:53 PM
Yup, they do:
http://www.autosport...7b2db834426eef3
But it's a mess - in my opinion.
#9 charliedurrant
charliedurrant
  • 519 posts
Posted 23 November 2011 - 12:11 PM
Maps, collected from various sources....
  • Attached File  Maps.zip   18.63K   64 downloads
