My Rover Mini 1995 1275cc SPI won't start.
Battery is charged, engine turns over, sometimes it runs for less than a second, but most of the time nothing.
I checked the vacuum pipes and they were ruined so they have been replaced.
I've checked the resistance of the HT leads, and a couple of them are just out of range (according to the manual).
4.3 kOhms
4.7 kOhms
5.0 kOhms
5.0 kOhms
The manual says they should be between 5-15kOhms.
Does this sound like the cause of the problem, or is it something else?
Spi Ht Leads Resistance
Juddling
, Nov 12 2011 11:56 AM
4 replies to this topic
Posted 12 November 2011 - 11:56 AM
Posted 12 November 2011 - 12:04 PM
No problem there, plug lead resistance is negligible compared to the plug gap, it just damps out RF interference, as do resister spark plugs.
You could try a little splash of petrol in the inlet, to help decide if it's a fuel or ignition gremlin.
Posted 12 November 2011 - 02:52 PM
Put some petrol in the inlet and it started, then konked out (once it was out of fuel)
second time, it kept running
maybe a weak fuel pump or some crap in the injectors. i'm just about to go and buy some injector cleaner additive
Posted 12 November 2011 - 03:12 PM
Temperature sensor, or wiring possibly? If it doesn't know how cold it is, it won't know how much extra fuel is needed.
Posted 14 November 2011 - 09:04 PM
how do i test the air intake sensor?
It seems to be starting the car for the first time that is the problem, after I put some fuel in the manifold, it runs all day.
