Rust Prevention
Posted 16 November 2011 - 04:03 PM
I've got some rust on the inside of my car on the footwell, I was wondering what product / products i can use to seal up the rust and to stop it from spreading. Because it is on the interior and will eventually be covered by the carpet i'm not too worried about it being pretty,
Thank you.
Posted 16 November 2011 - 04:40 PM
Posted 16 November 2011 - 04:51 PM
Rust in Peace
Loctite Rust Remedy
Hammerite Kurust.
I have no idea how effective these are but its worth a try.
Posted 16 November 2011 - 05:00 PM
Edited by AVV IT, 16 November 2011 - 05:02 PM.
Posted 16 November 2011 - 05:04 PM
Posted 16 November 2011 - 05:17 PM
Posted 16 November 2011 - 05:20 PM
Sorry but is nt etch primer zinc based???
Quite possibly, but the only stuff I've ever used comes in aerosol form and therefore only provides a thin coat. I would always therefore use a thick brush on zinc rich primer over the top if possible and only rely on the etch pirmier for it's etching into the metal properties.
Posted 16 November 2011 - 07:51 PM
Posted 16 November 2011 - 08:10 PM
so are you saying that the etch primer by itself is nt good ,you need to put something over it??
Yes (or at least that's my opinion of the stuff I've used any way)
Posted 17 November 2011 - 05:45 PM
Posted 21 November 2011 - 04:41 AM
Posted 21 November 2011 - 10:21 AM
If its badly pitted then i would recommend replacement of that section otherwise no matter what you use over time you will end up doing something to it.
Once you are happy with the area if its bare metal then a light coating of etch primer should be used first. This will aid adhesion of the next layers of paint.
As its an etch product, its slightly acidic that will allow it to grip to the bare metal then as you apply successive layers of other paints primers etc they will then stay attached shall we say. I don't think its Zinc based so it will need other layers of primer paint etc to fully seal the surface. Use zinc primer on top of etch but like i found out each layer of paint does require the right time between coats for the solvents in them to evaporate correctly. If you do not do this then you will get paint reaction. (been there done that)
Posted 21 November 2011 - 08:41 PM
Posted 21 November 2011 - 08:53 PM
