which brings me to the fit of my doorstep panel to the outer sill. The outer sill is a genuine heritage item. The doorstep is one of those repair panels + bottom of the 1/4 panel combined. I bought this pattern part as both curved parts of the doorstep were rotten. I cut off the 1/4 panel piece as I had to slit and weld up the B post repair to make it look more like the original post and less laughable than this.
I've trimmed, profiled and Cleco pinned the doorstep panel to the inner sill and it's fairly close to where I want it regarding the door gap and alignment. However, I've got to work out how the doorstep and outer sill are going to meet under the door and finally weld up.
Looking down the length of the doorstep repair panel, the seam that'll be plug welded to the outer sill is absolutely dead straight. The corresponding seam on the outer sill is slightly curved, I assume to follow the contour of the door. It's widest point looks like it's under the centre of the door, (Ah the door, the centre of the Mini universe) Looking at unrestored Minis rusting on the road outside my office, the black trim underneath the doorstep closely follows the contour of the door. On mine, the doorstep seam runs in a straight line so any trim would look narrower under the middle of the door and wider at both ends.
I'm interested to hear how others have tackled this. It doesn't look easy to bow the doorstep panel to match the outer sill's profile beneath it. It's heavily profiled after all but it would follow the door's profile better. Or could I assemble the panels as they are and trim and add material so the plug welded seam follows the door's profile better?
Thanks,
Adam
Edited by BusheyTrader, 19 November 2011 - 12:33 AM.
