Mg Metro Cam Maximum Revs
12 replies to this topic
#1 racingbob
racingbob
  • 3,061 posts
Posted 19 November 2011 - 09:17 PM
when would a mg metro peak revving your engine as no point revving it more than when it peaks
would it be about 5500 or less
#2 ministar
ministar
  • 835 posts
Posted 19 November 2011 - 09:44 PM
It does depend on several things.. but.. max rpm is at 6200 but power is from 1000-5800. This taken from the camshaft directory that used to be on here somewhere!!
#3 racingbob
racingbob
  • 3,061 posts
Posted 19 November 2011 - 10:14 PM
so its still pulling till reaches 5800. i havent tried it just about finished running in now only taken it to 5000 once in third
#4 maggies_minder
maggies_minder
    TMFs New official Spamster
  • 4,393 posts
Posted 19 November 2011 - 10:57 PM
as ive put in your other thread which is exactly the same :blink:
my MG metro engine has been over 6k before and daily sees 5k before every gear change.
#5 ministar
ministar
  • 835 posts
Posted 19 November 2011 - 11:02 PM
It does depend on other things though so probably not 'accurate' enough.
#6 maggies_minder
maggies_minder
  • 4,393 posts
Posted 19 November 2011 - 11:12 PM
whats not accurate enough? im a little confuuused.
mines a standard MG metro with a typical stage 1 getup
Edited by maggies_minder, 19 November 2011 - 11:13 PM.
#7 Cooperman
  • 23,294 posts
Posted 19 November 2011 - 11:26 PM
The Kent 266 is a very similar cam profile & lift and it gives max power at about 5800 rpm. So, for the very best performance you would change up at around 6300 rpm to keep the power in the middle of the graph so that you pass through max power in the next gear.
#8 maggies_minder
maggies_minder
  • 4,393 posts
Posted 19 November 2011 - 11:30 PM
im not brave enough for that cooperman.
#9 Cooperman
  • 23,294 posts
Posted 19 November 2011 - 11:38 PM
That would be the figure for absolute max performance with that cam. As a general driving cam you need to look at the torque curve and drive so that the max torque is mid-way between gear changes. It's probably around 4800 rpm, so allowing an average rev drop of, say 1200 rpm between gear changes at c.5000 rpm, you would change uo at 5400 rpm to keep it at optimum torque.
I use a 286 and when really trying, as on a tarmac stage, I peak the power at 6400, so I change up at c.6800 rpm and the revs drop to about 5700 rpm with my gearing.
#10 racingbob
racingbob
  • 3,061 posts
Posted 20 November 2011 - 01:22 PM
thanks for that info as i have only had race cars revving to 8000 with race scatter cams
#11 minimart
minimart
    Just On Tickover
  • 9 posts
  • Local Club: HELP ME DECIDE?
Posted 05 December 2011 - 09:47 PM
Happy belated Birthday cooperman
#12 Cooperman
  • 23,294 posts
Posted 05 December 2011 - 10:11 PM
Well thank you for that. I went out with my 17-year-old (just) Grandson in his 1997 Mini MPI and his road driving is very good already. Then my 21-month old Grandson arrived for dinner with my son and his wife. so it was a very good day.
#13 minimart
minimart
    Just On Tickover
  • 9 posts
Posted 06 December 2011 - 06:36 PM
Sounds like a real nice day glad you managed to get the spin in the mini,
and glad you enjoyed it, mart
