I have found that its the alternator screeching under load. it seems that when it screeches, it will also resist turning and then wear the belt badly.
anyway, I got it running great yesterday during the day, then went out in the night, started it up and when I turned the lights on, the screeching all started again.. then I sat there for a while turning the lights on [screech] and off [silent] - so im pretty certain its the alternator.
can these be serviced ? if they can ill whip it out and get it done.. if not, the minispares alternator is cheap enough http://www.minispare...44&prod_id=2255
but I need to get running asap for the VIC test
thanks.
J.
