A Stupid Immobiliser
9 replies to this topic
#1 charliedurrant
charliedurrant
  • 519 posts
  • Local Club: There isn't one down my way
Posted 20 November 2011 - 12:47 PM
Hi,
I have an old mini and I don't want to really fit a full alarm imobiliser. I was wondering if there was a simple system that:
- when you turn off the engine a timer kicks in and throws a switch. The switch would the be inline with the ignition wiire or something appropriate.
- to start the car you would have to throw the switch
I hope my explanation is understandable.
If there is anything like this available or am I simply being stupid?
Charlie
#2 david@skeggyminis
david@skeggyminis
  • 352 posts
Posted 20 November 2011 - 01:27 PM
you could fit a hidden push botton that you have to hold in to start the engine on the key
#3 firefox
firefox
  • 1,102 posts
  • Local Club: will find one when on the road
Posted 20 November 2011 - 02:00 PM
fit an electic fuel pump and switch it somwhere under the dash
#4 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Hi,
Here are some ideas:
http://www.the12volt...elays/page2.asp
Edited by xrocketengineer, 20 November 2011 - 02:04 PM.
#5 joshspragg
joshspragg
  • 984 posts
  • Local Club: M4 minis
Posted 20 November 2011 - 02:04 PM
i just got a little switch (in a hidden place) and if you flick that the engine wont start, and hazards start flashing if you dont flick the switch off. thats quite handy,
#6 charliedurrant
charliedurrant
  • 519 posts
Posted 20 November 2011 - 03:07 PM
Hi,
Thank you - the passive starter switch is exactly what I want. And thanks for the other comments too.
I assume the blue boxes on the link are relays? How can I find out the correct ones to buy?
Charlie
#7 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 20 November 2011 - 03:37 PM
I believe that they are universal SPDT (single pole, double throw) relays, however apparently Bosch set the standard. See here:
http://www.bcae1.com/relays.htm
#8 charliedurrant
charliedurrant
  • 519 posts
Posted 20 November 2011 - 08:00 PM
I know I'm being hand held here ....so I need two of these:
http://uk.farnell.com/jsp/displayProduct.jsp?sku=1414070&CMP=e-2072-00001000&gross_price=true
Charlie
#9 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 21 November 2011 - 05:58 PM
Looking at the specs for the Panasonic relay indicates that it is equivalent to the Bosch relay. The terminals are the same. There is a four terminal version of the Panasonic relay that is missing terminal 87a (normally closed contacts) but you do not need it anyway for your application, so either relay version should work.
#10 charliedurrant
charliedurrant
  • 519 posts
Posted 21 November 2011 - 08:59 PM
Thanks very much for confirming...
Charlie
