Fuel Pumps
5 replies to this topic
#1 dean.austin
dean.austin
  • 212 posts
Posted 22 November 2011 - 09:55 PM
hello everyone just wondering what fuel pump to go with you see im running a weber45 and i was told that i should use a solid state fuel pump. now the machanical one i have the vlaves in it are gone so i need a new one any way so should i go with the electric one or the same fuel pump that i had before
thanks . Dean Tracey
#2 jamiestevenbell
jamiestevenbell
  • 637 posts
  • Local Club: DCMOC
Posted 22 November 2011 - 10:14 PM
go for a facet solid state fuel pump and how many bhp you running with your webber out of interest
#3 Cooperman
  • 23,364 posts
Posted 22 November 2011 - 11:58 PM
For a Mini, even with a Weber, the ordinary Facit road pump is quite sufficient.
On my rally Mini with twin H4's I use two of those pumps, piped in parallel and individually switched to ensure 'fail-safe' fuel supply, but even with just one switched on I have no fuel supply problems even when it's doing about 10 to 12 mpg on tests. I mount mine under the rear horizontal seat base inside the left-hand side of the rear sub-frame. I also use a fuel pressure regulator just before the carbs.
A 'hidden' fuel pump isolator switch make the car more secure.
I hope this helps.
#4 dean.austin
dean.austin
  • 212 posts
Posted 23 November 2011 - 06:06 PM
em im not shore what bhp becouse havnt got it tested and i need a new distributor. its got a high lift cam with a lighten flywheel , s-r-e head , lcb and is bored to 1380 so i donno realy but id like to find out
#5 mk1leg
mk1leg
  • 9,343 posts
Posted 23 November 2011 - 07:12 PM
I fitted a facet on my Swiftuned mini..................
fitted to the rear sub..............
#6 dean.austin
dean.austin
  • 212 posts
Posted 23 November 2011 - 08:58 PM
and how does it work for yah is it effecient
Edited by dean.austin, 23 November 2011 - 08:58 PM.
