Resistive White Wire
19 replies to this topic
#16 firefox
firefox
  • 1,102 posts
  • Local Club: will find one when on the road
Posted 25 November 2011 - 04:25 PM
Yeah i heard that ballast coils were becoming dearer to buy
#17 firefox
firefox
  • 1,102 posts
Posted 25 November 2011 - 04:42 PM
They've always been more expensive firefox.
AHHHH rght i thought i read it somewher
#18 Cooperman
  • 23,327 posts
Posted 25 November 2011 - 06:02 PM
I'll tell you what is expensive: it's the re-wiring of virtually the entire front loom when that 'effing pink wire' overheats and takes the rest of the adjacent wires with it.
I've twice had to do this re-wiring and it's around a 6 hour job, plus a lot of wire and connectors.
I've never found the 12 v coil cars hard to start.
#19 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 25 November 2011 - 06:13 PM
AccuSpark ballast coil = 14 GBP
AccuSpark standard coil = 14 GBP
Lucas DLB102 (ballast coil) = 20 GBP
Lucas DLB105 (standard coil) = 15 GBP
All on eBay U.K. So a ballast coil does not have to cost more than a 12V coil... certainly not double, not even for Lucas.
#20 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 26 November 2011 - 01:06 AM
If you return to the first page of this thread, the discussion that Dilligaf and I are having started with my describing how to retain the ballast ignition system by replacing the pink wire with an external ballast resistor and plain wire. I don't dispute that the pink wire can cause expensive problems. Far from it. If you read what I posted on the previous page you will see that I am proposing an inexpensive alteration that does away with the pink wire but does not require expensive coil replacement.
