Turbo Or Super ?
Posted 25 November 2011 - 11:38 PM
Just wanted to know about power potential, reliability, installation difficulty and costs and which turbo's are best. etc etc.
Posted 26 November 2011 - 10:20 AM
Advantage - low boost threshold
Disadvantage - Limited power (for charged engine), poor fuel consumption, high intake temps, fixed boost
Turbo
Advantage - More power than you need, variable boost, good mpg
Disadvantages - the temptation to up the boost
As for reliability, both are the same and cost is similar. There are cheap SC kits out there, but you get what you pay for. If you compare a suck through SC compared to a blow through turbo, the turbo is a more complicated build. But the results are better.
I'm biased of coures, but that's only because I made the right engineering decision!
Posted 26 November 2011 - 10:31 AM
Posted 26 November 2011 - 01:18 PM
Posted 26 November 2011 - 01:20 PM
Posted 26 November 2011 - 01:48 PM
Anyone know much about the performance differences between:
T3
T2
T2.5
GT1752(I think thats the right number)
I know that you have to mod the bulkhead to fit the T3 so i wouldnt want to do that.
I like the look of the mirage manifolds but theyre single downpipe unlike the LCB, does this have performance effects?
Posted 26 November 2011 - 01:54 PM
Posted 26 November 2011 - 02:02 PM
Posted 26 November 2011 - 02:56 PM
i.e. what power are you aiming for? once you know this you can choose the right turbo.
Posted 26 November 2011 - 03:59 PM
MED FIS head,
either SC typhoon ecu or emerald k6 ecu for engine management,
ultralight flywheel,
lightened, balanced and wedged crank?,
any more suggestions on a spec?
It will be a road car but i'd like big power.
Posted 26 November 2011 - 05:16 PM
Just to illustrate the difficulties ahead, with a supercharged engine the fuel demand for a given rpm and throttle position is always the same. The fuel demand for a turbo at any given rpm and throttle position depends on the boost the turbo is delivering that moment. The air/fuel ratio for a turbo needs to change with the boost level to get best performance and low throttle lag, so the mapping is considerably more difficult. When setting up a supercharged car, I could get the fuel injection working reasonably well in about two hours on a rolling road. A custom turbocharged application takes 7-8 hours of rolling road and several days of driving around and fiddling to get right. If you talk to anybody who is actually driving a turbo mini with 12+ psi boost, I am sure they will tell you that they are still working on getting their EFI mapping just right.
Posted 26 November 2011 - 05:24 PM
Posted 26 November 2011 - 06:52 PM
Phil.
Posted 26 November 2011 - 07:56 PM
Posted 26 November 2011 - 09:34 PM
Out of interest why 1380 & why the flash ECU ? Are you actually planning on injecting it or just running a carb ? The simplest & cheapest install will be a single carb & something like Megajolt.
Phil.
Because it's an spi so the typhoon ecu would just plug in. and 1380, i just thought it would have more power. am i wrong?
