Nitrous Oxide On Single Carb Setup
Posted 28 November 2011 - 06:40 PM
however i have zero experience with N20 kits on minis. im just turning over a few ideas in my head, and have now turned my thoughts to this.
please dont laugh at what might be silly questions.
with a "wet" kit, do you need to already be using an electric fuel pump, or can you use the mechanical pump? i wasnt sure if a mechanical one would supply enough pressure.
i did read something about about the n2o bottle pressure pressurising the fuel goig to the solenoid? but i think i may have been mislead there?
basically im looking at getting a kit for my 1310 with a single hif44, so if anyone can offer a rough instalation scheme i would greatly appreciate it.
Posted 28 November 2011 - 07:35 PM
Posted 28 November 2011 - 08:14 PM
www.nitrous.info
full of great diy info and builds
Posted 28 November 2011 - 08:54 PM
Re. the Nitrous bottle pressurizing the fuel, I've no idea where that came from but its wrong lmao.
Posted 28 November 2011 - 09:03 PM
firstly im not 16, and im not a numpty. (i also know n20 isnt "forced induction" but didnt know where else to put it)
Basically you run 2 fuel feeds, 1 as it is now, a permanent normal driving feed. And the second runs to the N2O injector to be injected with the N2O. You can get away with a mech pump on the normal feed but really you want a high volume elec pump for the N2O feed. It's a great performance upgrade, one I am putting on my 1310 build.
You will get people tell you your engine will explode and melt itself. Not true, if installed properly it is not more a problem than forced induction and WILL NOT melt your engine.
My advice is go with a wet kit as you said, don't be tempted to run a dry kit!
Minisport sell the full kits I think, and don't over do it with a huge injector!
Beej
Posted 28 November 2011 - 09:14 PM
Posted 29 November 2011 - 09:51 PM
installing an off the shelf kit will be no problem im sure, and im sure building my own wouldnt be too tricky either, as long as i can get some good info from the other sites etc.
off for a peek now.....
Posted 29 November 2011 - 10:09 PM
Posted 30 November 2011 - 08:28 AM
Posted 30 November 2011 - 08:29 PM
Posted 30 December 2011 - 12:21 AM
Posted 03 January 2012 - 10:16 PM
