Anyone know what the coloured cables on the clocks relate back to? and also can you use these for auxiliary guages as i'm gerring rid of my clocks?
Anyone Know What The Coloured Cables Relate To On Clock Plug?
loobylooby
, Nov 29 2011 03:32 PM
6 replies to this topic
Posted 29 November 2011 - 03:32 PM
Posted 29 November 2011 - 04:15 PM
When you say clocks do you mean like the speedo, fuel, water temp?
Posted 29 November 2011 - 04:18 PM
yeah theres a plug in the back of them
Posted 29 November 2011 - 04:21 PM
I think your best bet is get a haynes manual and look at the wiring diagrams in the back.
they normally control things like the back lighting indicator lights, feul and water temp readings things like that.
was there any specific ones you needed to know about?
Posted 29 November 2011 - 04:25 PM
i wanted to know what colours the indicators, high beam, oil low and battery low are, so i can fit LED's on the end on a new dash build.
Also can the others that go to fuel, water temp etc be used for separate auxilery dashes?
Posted 29 November 2011 - 04:27 PM
ah I see, yeah I think your best bet would be a Haynes manual, but you never know some one might know a couple of those. Have you tried posting in the technical section, you might get more luck there.
Posted 29 November 2011 - 04:31 PM
thanks
