Getting More Light On Dipped Beam Setting? How?
Posted 30 November 2011 - 03:52 PM
I'm sure this has been asked before but I cant really find any info, apart from doing the usual Wipac H4 bulb and unit conversion. So...
Now that the evenings are dark and I have to use my headlights I am finding that the dipped beam setting on my mini is, well, crap!
You get about 6ft of yellowish dim light that is useless for seeing where you are going. Compared to my mums r32 on dipped beam which is practically daylight!!!
The main or full beam lighting is fine because I have spot lights which makes a huge difference, but the dipped is still lacking.
Is there any modifications I can do to the lighting circuit or any alternative to the standard Wipac Quadoptics that give a far improved dipped beam illumination.
Any help would be greatly appreciated
Thanks!
Posted 30 November 2011 - 03:56 PM
Posted 30 November 2011 - 03:59 PM
Posted 30 November 2011 - 04:06 PM
The earthing is all fine, checked that recently.
Apart from making sure all the equipment is fine and in proper working order, is there anything that can be done to improve things?
Edited by freshairmini, 30 November 2011 - 04:07 PM.
Posted 30 November 2011 - 04:11 PM
Posted 30 November 2011 - 04:15 PM
But I will say the reason for the larger alternator was because I was put more audio equipment in so it would need it for that extra stuff.
Posted 30 November 2011 - 04:18 PM
Posted 30 November 2011 - 04:27 PM
And why did the later cars use the 70amp alternator if they didn't need it?
Posted 30 November 2011 - 04:33 PM
2 x headlight 110w
2 x rear light 10w
brake lights 42w
side lights 10w
spots 120w
no idea on heated screen and blowers
but all the lights comes to just under 300 watts.
amps x volts = watts
your normally running at around 13.5v * 45 amps = 607 watts so yeah should really be plenty of juice in a 45amp alternator.
Alternators don't actually pump out full power all the time, they supply what is demanded by the system. So if very little is on, it won't supply so much .
This is why the revs drop the more you switch on, the alternator as to work harder and puts more resistance on the engine
Saying that I've got a 70amp alternator on mine but the price was right and I needed a new alternator so no harm in a bit of overkill
Edited by lrostoke, 30 November 2011 - 04:36 PM.
Posted 30 November 2011 - 04:47 PM
I'd guess a test would be to compare the light brightness with standard wiring, then rig up a direct feed from the battery to light to compare the light output !!!!
If its brighter direct. bit of rewire using relays energised by the standard wiring, but with the power to the lights coming direct from the battery via the relay.should sort it out
Posted 30 November 2011 - 05:06 PM
and a fuse of course
Posted 30 November 2011 - 06:20 PM
