Size Of Torx Screws In Doors
9 replies to this topic
#1 runkthepunk
runkthepunk
  • 312 posts
Posted 01 December 2011 - 05:06 PM
Hello all
Just need to buy a Torx bit for my impact driver and wanted to ask whats the size of the Torx on the door hinges?
I would go and check but I don't have access to the door at the minute.
Its a 1996 spi door if that makes a difference.
Thanks :D
#2 R1minimagic
R1minimagic
  • 4,660 posts
Posted 01 December 2011 - 05:34 PM
I would tell you but it is freezing cold and dark outside, can you wait until tommorow?
#3 runkthepunk
runkthepunk
  • 312 posts
Posted 01 December 2011 - 05:41 PM
Ha ha yeah mate no worries.
I am going to start work on the door when I am next back up in a few weeks so want to have all the bits I need. So I am not in a rush really.
Also I may drop you a line nearer christmas if I need any extra bits from you!
#4 M J W J
M J W J
  • 976 posts
  • Local Club: not yet
Posted 01 December 2011 - 06:38 PM
As far as I am aware the door hinges on a mini are connected to the door by a posi drive machine screw. The other side of the hinge bolts to the door supports and inner flitchs with a stud that is part of the hinges and a 1/2" unf nut.
I don't know of anywhere on a mini where torx screws are used although I may be wrong.
#5 runkthepunk
runkthepunk
  • 312 posts
Posted 01 December 2011 - 06:41 PM
The later mini doors used Torx screws to attach the hinges to the doors and body. Earlier type doors used the posi-drive screws
But with BL/Rover I guess any mix of things is possible no matter what the year!
#6 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 01 December 2011 - 06:45 PM
Do believe its T30 from memory but I could be wrong. Its a large size thats all i can remember!
#7 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 01 December 2011 - 07:35 PM
t30 is the torx size and they are chuffing tight normally
#8 Mini 360
Mini 360
  • 4,933 posts
Posted 01 December 2011 - 08:04 PM
Aye if you can get the torn bit onto a socket ratchet it will make your life a LOT easier than a screwdriver style. Either way soak them in WD40 first!
#9 R1minimagic
R1minimagic
  • 4,660 posts
Posted 01 December 2011 - 08:47 PM
I think they are ok to remove as long as you have a good tool!
#10 runkthepunk
runkthepunk
  • 312 posts
Posted 01 December 2011 - 09:46 PM
Thanks everyone!
I will be using WD40 and a Sykes Pickavant Impact Driver with said T30 Torx bit.
Hopefully the Impact driver will be enough to get them moving then finish them off with a socket wrench
Cool
