Drop Gear End Float Between Gearbox And Transfer Case. What Should It Be?
9 replies to this topic
#1 mk=john
mk=john
  • 1,167 posts
  • Local Club: Milton Keynes Mini Club, Mini Cooper Register
Posted 02 December 2011 - 04:58 PM
Hi
My mini is a standard 850cc, and I am about to attatch the gearbox to the engine. Before I do this, I will temporarily attatch the transfer case to the gearbox and measure the drop gear end float, and adjust the thrust shims as required.
What is the correct value for the clearance I need to allow for? Once I know this I will then know if I need to buy new thrust washers (shims)
John
#2 Cooperman
  • 23,326 posts
Posted 02 December 2011 - 05:20 PM
I usually work on between 0.002" and 0.007".
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 02 December 2011 - 06:01 PM
I aim for 3-4 for helical, and a bit looser for straight cut.
#4 bmcecosse
bmcecosse
  • 9,699 posts
Posted 02 December 2011 - 07:22 PM
The thickness of the gasket has an effect - they come in various thicknesses. Better a bit loose rather than too tight!
#5 mk=john
mk=john
  • 1,167 posts
Posted 02 December 2011 - 07:45 PM
Hi
I have measured the gap with feeler gauges and it is 0.0035 (Helical gears)
So, this sounds ideal then?
#6 Cooperman
  • 23,326 posts
Posted 02 December 2011 - 07:48 PM
Perfick!
#7 bmcecosse
bmcecosse
  • 9,699 posts
Posted 02 December 2011 - 07:53 PM
IF the bolts/nuts are fully tight and the gasket compressed......
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 02 December 2011 - 08:13 PM
I have a vague recollection that when you picked up the box, we sorted the idler shimming then... or is this a different one ?
#9 racingbob
racingbob
  • 3,061 posts
Posted 02 December 2011 - 09:43 PM
if i can recall mine was about 6 - 8 but sounds fine
#10 mk=john
mk=john
  • 1,167 posts
Posted 02 December 2011 - 09:51 PM
Hi Guessworks
That was a different gearbox for a differrent engine. This is the hybrid box you built. Excellent box by the way!
