Ice Help
12 replies to this topic
#1 josh.goddard
josh.goddard
  • 398 posts
  • Local Club: Derbyshire Classic Mini Club
Posted 02 December 2011 - 08:25 PM
Well i am getting a friend at work to help me wire my ice in but i need a little help deciding what i need:
1. i have a boot liner kit in i want to have a sub mounted in the opposite side of the boot with the amp behind but what sub box do i need
2. what sub and amp do i want
3. the standard speaker in the back window i have removed the original speaker what speaker do i need to replace it.
Thanks Josh
#2 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 02 December 2011 - 08:55 PM
1: one that fits your sub of choice.
2: no one should tell you specific make and model, just recommendation of size/style of sub and what sort of amp.
3: If your having a sub in the boot you cannot have speakers in the rear shelf, unless you put them in enclosures.
Edited by Ruckus, 02 December 2011 - 09:03 PM.
#3 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 02 December 2011 - 09:02 PM
So now to be a bit more directly helpful.
1: optimise automotive make good sub enclosures, but what you need depends on the boot liner kit you already have and the size of sub you go for. But to do it properly you should really make one from fibre glass (rear) and MDF (front) yourself.
2: It depends on budget, but a 4 channel unit with 50 to 150 watts per channel. You can then use 2 channels bridged for the sub and the other 2 channels for the full range. Most find a 10" sub is prefect in a mini but if you want mega bass and go for a 12 or higher, then you will need to be prepared to build the enclosure heavy duty and budget plenty for soundeading...
3: In any small car full range speakers have no place behind you. Best practise is a set of 6.5" comps mounted up front in pods on the kick panels or in the doors. With the tweeters on the dash or In the A-pillar.
All this has been covered many times in this section, have a read of some of the posts it should help you decide what to go for. :D
Edited by Ruckus, 02 December 2011 - 09:14 PM.
#4 Brams96
Brams96
  • 2,308 posts
Posted 02 December 2011 - 09:03 PM
This is all very subjective stuff. Answering a few questions might help us direct you towards what you might need.
What type of music do you like listening to?
Do you like bassy sounds or crisp & clear music?
What is your budget roughly?
Do you want a hidden install or something on display?
Do you plan on making any enclosures or DIY'ing anything yourself or buying 'off-the-shelf' items?
#5 josh.goddard
josh.goddard
  • 398 posts
Posted 02 December 2011 - 09:13 PM
i like a mixture of drum and bass, dubstep and R&B
i prefer bass
i dont want to be spending alot but i want cheap stuff which is ok as i can get audio bits at trade price anyway
and i dont mind making my own if i have some plans to work from but i would like off the shelf
and the other thing is i want it quite hidden it like it in the side pannel opposite to the petrol tank and was going to hide the amp behind the sub as i dont want to loose my boot or union jack board on the back of my boot liner kit
hope this helps a little more josh.
Edited by josh.goddard, 02 December 2011 - 09:16 PM.
#6 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 02 December 2011 - 09:18 PM
It not going to be the cost of the kit as much as its going to be the cost of the install.
If you want bass and you don't do the install well, your car will sound like a noisy buzzing mess!
Edited by Ruckus, 02 December 2011 - 09:19 PM.
#7 josh.goddard
josh.goddard
  • 398 posts
Posted 02 December 2011 - 09:24 PM
the install for me is free so long as i mount everthing and run all the wires
#8 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
I think you really need to spend some time reading through the install projects and other threads in this section, as without being rude ( really I'm not :) ) some of your plans are impossible and seem to lack a understanding of the basics. Again sorry if that sounds rude I really can't put it any other way!
Edited by Ruckus, 02 December 2011 - 09:28 PM.
#9 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 02 December 2011 - 09:26 PM
You say the install is free??!
So your getting sound deadening for free?
Edited by Ruckus, 02 December 2011 - 09:27 PM.
#10 josh.goddard
josh.goddard
  • 398 posts
Posted 02 December 2011 - 09:33 PM
another little question i have is do any sub and amps in boxs like you get from halfords fit in with a boot liner kit
#11 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 02 December 2011 - 09:49 PM
Again it depends what kit you have. Best to sound deaden the boot, fit the kit and then measure up.
Most (but not all)of the all in one sub/amp combos are tat though.
But please avoid Halfords!
Almost everything they sell audio wise is aimed at the bling per buck Chav market.
Have a look on Car audio direct, one of the best online ICE retailers.
But if your on a budget pre-owned might be the best route... :)
Edited by Ruckus, 02 December 2011 - 09:52 PM.
#12 josh.goddard
josh.goddard
  • 398 posts
Posted 02 December 2011 - 10:11 PM
http://www.caraudiod...dio-direct.html i quite like this one if it will fit
#13 Masterhalifax
Masterhalifax
  • 56 posts
Posted 04 December 2011 - 04:17 PM
You need to be a little more 'help yourself' this product has measurements, so measure your boot and find out.
If i was you i would go for the 'type R' sub, much better, but yet again depends on your budget.
You have to think about the whole package, not just buy one item and find out you bought an amp that isnt powerful enough to run the speakers.
As above look at some of the projects and other links, lots of usefull info.
Good Luck
